Hermle movement with wrong pendulum?
Discussion in 'Clock Repair' started by Jasons34, May 19, 2017.
  1. Jasons34
    Jasons34 Registered User
    Jan 1, 2016
    775
    Millwork
    Pennsylvania
    i just bought a Ridgeway school house clock that has a hermle 340-020 45cm which I believe has the wrong length pendulum. The clock with its rating nut all the way lowered runs about 4 minutes fast in 3 hours. I'm not sure where you measure from when figuring out the length of the pendulum on hermle movements.
  2. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    623
    Science teacher, writer
    Lancaster, Ohio, USA
    Is there room in the case for a longer pendulum? Timesavers has a large collection of Hermle pendulae. You'll just need another pendulum rod.
    M Kinsler
  3. Jasons34
    Jan 1, 2016
    775
    Millwork
    Pennsylvania
    See that's where I am stumped. The case has a label on the label (official Ridgeway label) that shows how to adjust and set up so obviously this case goes with the hermle movement. The dial has Ridgeway on it. Even the inside on the case is cut out to accept the front of the movement and chime assembly. There are no extra holes anywhere which would be evidence of a swap with a whole different movement. Only thing I can think of is someone replaced the original 340-020 with another 340-020 which used a longer pendulum but they used the pendulum from the first original movement. I had thought that wear was causing the issue but I get a very nice swing and ontop of that the chime and strike are very smooth (which are usually the first trains to show wear). The backside of the pendulum has a hole in (not sure what that is for but my other one has this same hole so it's legit) so I took 2 washers and used the hole to thread a short bolt holding the washers in place just to see what happens. I have the rating nut at the same spot as prior (1/8 inch of threads showing) and now the clock is running a bit slow. So would this be an incorrect pendulum ? Where do they measure from when they figure their 45cm length?
  4. Willie X
    Willie X Registered User
    8,076
    29
    That would be a 341 movement, if it has a pendulum. Often these pendulums get dropped and this results in the threaded part breaking off just above the nut. I don't know what type of pendulum you have but the rating screw can always be replaced, or lengthened. IF the case is long enough ... as K33 already mentioned.
  5. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    Donor NAWCC Member
    Jul 4, 2009
    1,874
    Hermle measures from the suspension post to the rating nut approximately. The real rating is for a theoretical pendulum
  6. Jasons34
    Jan 1, 2016
    775
    Millwork
    Pennsylvania
    Willie you are correct about it being a 341. My eye site is bad. Anyways so from the post to the end of the rating nut should be 17-3/4 inches which is what I have. I also compared the swing of this one to the other 2 I have and they are the same. Over night I lost a half minute so I lowered the rating nut so it's only caught by a few threads. I still have those washers on the backside which has helped a lot. I'm now leaning towards what Willie said about the threaded part being broken off. Is there a set length to these pendulums on what the threaded length should be?
  7. Willie X
    8,076
    29
    You can look at the tip of the threaded part. From the factory the tip is pointed or rounded up. When broken off it will have sharp ragged edge. Also, there are usually rub marks, or scrapes, where the rod or stick enters the top of the pendulum. These marks will often tell you where the pendulum went. There may also be ghost marks on the inside of the case where the pendulum or rating nut has scraped the case from time to time over the years.
    I rarely do any pendulum measuring. Numbers and measurements are often misleading.
  8. Jasons34
    Jan 1, 2016
    775
    Millwork
    Pennsylvania
    The pendulum threaded part and rod itself are all one piece so I'd have to buy a whole new pendulum. Merritt's has them for $15. I looked at the end of the threaded part and it's not broken. What I did now is removed the rating but and flipped it sothe flat part is at the bottom and the tapered is against the bob. That way I can slide the bob over the tapered part as far as it can go to get it even lower.i have the nut caught by a few threads and now it's running a hair slow.
  9. Willie X
    8,076
    29
    Also, you can easily change the suspension spring for an extra mm ot two. Need more, there are about 6 different length pendulum leaders available for yout clock.
  10. harold bain
    Donor NAWCC Member
    39,961
    You could add some weight to the bottom of the pendulum bob (on the inside)to compensate. You are not far off now.
  11. Jasons34
    Jan 1, 2016
    775
    Millwork
    Pennsylvania
    Well as I have it now the clock is slow so thats a good thing. Just need to adjust the rating nut upwards. This clock was going to replace a Chinese "regulator" clock that has a very noisy fly assembly but my wife hates how I have to adjust this thing. There is no door for the pendulum so I have to pull the clock from the wall to make any adjustments plus tilt the clock to get it started and then quickly level it. So I'm going to make sure it runs for a few weeks and then toss it in the basement with the rest of my "retired" clocks
Similar Threads - Hermle movement wrong Forum Date
Autonight silence on hermle movement query? Clock Repair Sep 20, 2017
Hermle Pendulum movement replacement Clock Repair Aug 23, 2017
Hermle floating balance movement Clock Repair Aug 10, 2017
Adding night shut off to Hermle movement - missing post for installation Clock Repair May 18, 2017
Purchased the wrong pendulum for Hermle Grandfather clock movement Clock Repair Jul 15, 2012
