Jeff
Is there anyway to clean a Hermle movement without taking it apart?
Jeff
Jeff
Simple answer Jeff, no.
It s like asking can i wash my feet with out taking my socks off![]()
agree with tearing it down to properly clean, especially if in clock repair business, BUT if it is ones own what will it hurt by attempting to clean assembled using using solvent, air pressure etc. IF the bottom line is to replace movement? Might one put off this expense a short while (penny saved) In case of extreme dirty feet I would rather try washing my feet with SOCKS ON before getting a foot replacement. inquiring minds! hoo-boy
Since it is your own clock, you may do anything you like in terms of cleaning. BUT- and it is a big one - you should somehow document what you have done. You never know when you may get hit by a truck, and someone else will be coming along behind you. Also - the biggest problem with not disassembling the movement, besides the obvious inability to completely remove all traces of dirt, is you will have a tough time getting all of the cleaning medium out of little spaces like beneath the clicks, and inside the springs, especially the coils in close to the arbors.
