hermle movement 1161-853 H.S. 114/60
Discussion in 'General Clock Discussions' started by john 05, Jul 16, 2017.
  1. john 05
    john 05 Registered User
    May 30, 2013
    39
    Hello
    I have a Hermle 1161-853 H.S. movement (winding holes all aligned) and the center pulley is not aligned with the others (not turned the same way) The barrel can go in only one way and the cable, one spot to the support of the movement. May this be the way it is? Thanks John
    [​IMG]
  2. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    567
    Retired Military
    Hampton, Georgia
    John, for you and ME, I hope some one who reads this will tell you what you are wanting to know.
  3. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Member Donor
    Jul 4, 2009
    1,882
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    The cables ends are attached to the center of the movement front to back.. At the full up and down of the cable on the drum, it will go from one end to the other and only be at the center of the drum only when half way down. The pulleys are tilted opposite because the ends are both attached to the same center plate.
  4. john 05
    May 30, 2013
    39
    Thanks for the reply, most of the cable weight clocks, when all the weights are up, the pulleys are in the same angle at the top. (all three) This movement was only made for a short time (three winding hole in a line). maybe this is normal for this movement. Thanks John
Similar Threads - hermle movement Forum Date
Hermle Movement General Clock Discussions Jun 7, 2017
Hermle Movement General Clock Discussions Apr 10, 2017
Hermle 1050-20 movement with 5 chimes General Clock Discussions Mar 14, 2017
Hermle 1161-853 movement issues General Clock Discussions Jan 21, 2016
Hermle 1051-850 94 cm triple chime grandfather movement General Clock Discussions Jan 9, 2016
