Hermle balance Wheel adjustment
Discussion in 'Clock Repair' started by Frank Manning, Jul 29, 2013.
  2. Check it out in the NAWCC Events forum:
    Talk about the upcoming National Meeting
    Preregistration is now closed.
    Visit the site for our New Member Walk In Deal.
  1. Frank Manning
    Frank Manning Registered User
    Nov 22, 2005
    343
    Vernon, CT
    Hi,
    I have a Hermle movement that has the balance wheel escapement and has the vertical coiled spring. The wheel gets a little over a total of 360 degrees motion. I have the adjustment all the way over on the slow side and it is still running a few minutes fast every day. What else can be done to slow it down a bit?
    Thanks, Frank
  2. hookster
    hookster Registered User
    Jan 14, 2011
    1,998
    Pharmaceutical Consultant
    Pottageville Ontario Canada
    That is, for sure, adequate rotation and suggests that your problem is not with the balance, unless someone messed around with the fork, banking pins or other delicate parts, which has been known to happen.
  3. shutterbug
    38,931
    419
    Is it running in beat? Any chance it might have picked up a magnetic charge? Sometimes the vertical wire running through the balance needs work or replacement - worth a peek. Generally, fast relates to power loss in the train, but typically it's accompanied by poor rotation. Yours sounds healthy enough. If you used a magnetized screw driver near the balance I'd eliminate that first.
  4. bangster
    bangster Moderator
    18,618
    203
    Open the banking pins a teeny bit. (Now I'll duck and run for cover.)
  5. hookster
    Jan 14, 2011
    1,998
    LOL :cyclops:
  6. Fred Reiss
    Fred Reiss Registered User
    Apr 27, 2010
    438
    Missouri
    I had the opposite problem and it turns out the balance unit may have been gummed up from a prior repairman using oil on it. In your case, a prior repairman may have removed weights on the balance wheel to speed up a sluggish unit. You might be able to see this by carefully examining the outer ring of the balance wheel for any marks, etc. If weight was removed, the Hermle service manual suggests adding weight back to the wheel using weights from a scrap unit or by making your own using taper pins. QUOTE=Frank Manning;797597]Hi,
    Thanks, Frank[/QUOTE]
  7. bangster
    bangster Moderator
    18,618
    203
  8. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    59
    First, make sure it is really the balance wheel that is the cause.
    Loose hands or such might allow the time to move ahead slightly.
    It would be a shame to tinker with the wheel when something else
    was the real issue.
  9. Jay Fortner
    Jay Fortner Registered User
    Feb 5, 2011
    5,020
    23
    Clockmaker/Watchmaker
    Chiefland,Fl.
    More like Fred said.
  10. harold bain
    harold bain Registered User
    NAWCC Fellow NAWCC Member Deceased
    40,850
    130
    deceased
    If I'm reading this one correctly, it's not a floating balance. You might be able to make a correction using the hairspring, if it has any extra to lengthen it. You will then need to set it in beat.
    No weights to play with on these.
  11. Jay Fortner
    Feb 5, 2011
    5,020
    23
    Chiefland,Fl.
    No Harold this statement makes me think we're talking old floater
  12. harold bain
    40,850
    130
    deceased
    Yeah, I suppose vertical would make it the helix spring, rather than a hairspring. Perhaps a few weights have been removed.
  13. Frank Manning
    Nov 22, 2005
    343
    Vernon, CT
    Hi everyone, and thanks for all the good advice. I did go to the .PDF file and decided to take an unusable floating balance and punch out a few of those little pieces. Then I pressed them into the balance in question. I did find that someone had removed some and not done them as opposing pairs. With that fixed, I am now working on setting the speed once again.
    Thanks again, Frank
