Hello I am working on a Hermle 340-020 movement. I dismanteled, cleaned and oiled the whole clock but the problem is that it is running TOO fast.
In 1 hour it gains 3-4 minutes. I tried regulating the balance wheel and added 4 little weights to it and it stills going too fast. I also tried using another balance wheel and installed another mainspring barrell from another clock.
Should I try to add more weight to the balance wheel?
Thank you.
Thank you.
