Good Day!
I'm looking for advice regarding difficulties in regulating an Hermle 130-070 movement in a New England Clock case circa '84.
Using the Clockmaster app I have graphed the BPH over a week and found a very linear acceleration of the S/D Error from .05 seconds/day when fully wound to 84 seconds/day a week later. This caused again of 4 1/2 minutes in a week. Should I replace the spring and hope for a more steady rate, or is there a way to adjust some of the difference out?
Also, I have read that rotating the weights around the floating balance wheel by 1 dot should equate to 10sec/day and I have not found that to be the case. Adjustment seems to be wildly arbitrary and hit or miss.
P.S.- the balance is clean, un-lubed, and spinning about 540 degrees (based on slo-mo iPhone video)
I'd appreciate any advice/education.
