Hello! New to forum. If this post is in the wrong place, kindly redirect or advise. I have a Hermle 1171 movement with triple chime and automatic night shutoff function. Early in its life it had the 3rd wheel of the time train replaced under warranty. In the Westminster chime mode the clock works flawlessly, striking and chiming as appropriate. I have recently decided to use the ANSO funtion. In the AM it is supposed to once again strike and chime at 0700. However, at 0700 there was no strike, but there was 4 quarter notes. At 0715, 8 notes, at 0730, 12 notes, at 0745 NO notes, at 0800 16 notes followed by 8 chime strikes. From 0800 and beyond all was normal.
I moved the double wheel cam assembly a few teeth at a time to get the lever to drop at 0700 and am pleased that there is now 7 strikes and 16 notes at that time. I would like this to be the first sound I hear after coming off the night shutoff mode each AM. HOWEVER, at 0630 there are now 12 notes struck, at 0645 silence, and at 0700 normal. What if anything can I do to eliminate the 0630 chiming. Is there somehow a problem with the hour tube that I am not understanding? Might this problem be related to the earlier replacement of the time train 3rd wheel?
I am baffled, as the clock functions as intended when not in the ANSO mode. I am looking for an easy fix that does not involve sledge hammers and all input is appreciated. This is a grandfather clock movement, not a cuckoo clock, and it is driving me cuckoo!:cyclops::cyclops:
