Hello and Good Day to All!! I have a question/questions regarding an Hermle 1161 movement out of a Ridgeway clock...it is a cable driven triple chime unit. The clock runs well, keeps good time, and the strike train is not sluggish at all. I did 3 bushings on that train. I also did 2 bushings on the chime train, but the chimes seem to slow at some points and become 'jerky' when going thru some sequences on the Whittington and St Michaels melodies....The Westminster sequences on all quarters seem steady throughout ALL sequences, on ALL the quarter hours. I am assuming that there is more power draw on the train with the 8 note melodies vs the 4 note melodies. Am I correct? When I apply a little pressure, not much, on the weight the sequences are fluid and not jerky. So, to me, logic does say that there is possibly a bent pivot? I disassembled twice and checked possible culprits. I even went thru the motion of 'correcting' any pivot that I perceived of being bent, even though it probably wasn't....All the hammers are lined up properly with the chime drum pins..What other source of power grab should I look for..Do the cams on the drum itself get loose? Could it be a larger pivot got bent when prying off the front cams? Or even the rear wheel when removing that from the back plate.?? Could levers be getting hung up? they seem to be moving OK...Which brings me to another set of questions...How do you know for sure if those smaller pivots are, or aren't bent
.Is there a tool or method of checking/repairing to know that they are correct?...other than visual...?
Well I've rambled on and am sure I've gone over my time limit.....SO, any feedback on ANY of these questions would be greatly appreciated.
Best,
Bob
Best,
Bob
