Hermle 1050-20 movement with 5 chimes
Discussion in 'General Questions' started by oldlawman, Mar 14, 2017.
  2. Welcome to the new home of the NAWCC Message Board
    We are glad to see you have found us Guest. If you like what you find here, please let your friends know about us.
  1. oldlawman
    oldlawman New Member
    Mar 14, 2017
    I recently acquired a Hamilton mantel clock with the above movement. It has a selector for five different chimes at 3 o'clock, and runs perfectly, but I don't know how to turn the chimes on. Any help appreciated.
  2. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    555
    I am not saying that you are wrong, but I have never seen a mantle clock with 5 chimes. Are you sure?
  3. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,343
    12
    The standard Hermle 1050 movements have three chime melodies - Westminster, St. Michael, Whittington - and a silence option. I seem to recall the top position is silent, followed by the three melodies below. Try pushing the lever down.
  4. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    961
    Also check around the chime hammers for a packing block that was put in place during shipping and may be blocking the hammers?
  5. Robert Gift
    Robert Gift Registered User
    Nov 12, 2012
    184
    Wonderful! What are the five chimes? I know of only three in a small clock: Whittington, St. Michaels, Westminster.
  6. oldlawman
    Mar 14, 2017
    You made me get out the magnifying glass (should have done that before posting) and you are of course correct - top is silent, then Whittingham, St. Michael, and Westminster. It doesn't want to chime in any of those positions, so I guess I better take it to a clock guy. Thank you so much.
  7. oldlawman
    Mar 14, 2017
    You are right (after looking at it with a magnifying glass). Only three :)
    - - - Updated - - -
    I will check for a packing block, although this is a used clock and I didn't notice anything like that when I looked inside. If that isn't the problem, I'll take it to a clock guy. Thank you so much for your help.
Similar Threads - Hermle movement chimes Forum Date
Hermle 1051-850 94 cm triple chime grandfather movement General Questions Jan 9, 2016
My problem...With Hermle movement with Westminster Chime General Questions Jan 19, 2015
Hermle HM1050-020 triple chime movement chime block alignment General Questions Nov 2, 2014
Custom triple chime wall clock with Hermle movement General Questions Oct 26, 2011
Custom China grandfather clock change to Hermle triple chime movement General Questions Jun 18, 2011
