Jack Feldman
A while back I purchased what I believed was a Herman Miller World's Fair clock, model 4084, designed by Gilbert Rohde. After doing as much research as I could I'm pretty confused. At first glance the dial looked right, but it has no manufacturer marking, and I stupidly neglected to notice the power-interruption indicator window under 12:00, which I know was a Telechron mainstay. I haven't seen another example of this clock—or any Herman Miller clock of the period--that has this. I didn't buy the clock in person, and it wasn't until I'd received it that I was able to read the plate on the back, which identifies it as a Telechron. The only element on the outside of the clock that refers to Herman Miller is the World's Fair plaque on the back. Do any of you know if this clock is "right"? I haven't seen this variation mentioned in any blogs or histories of the companies that I've found.
I've also been trying to find information that identifies the model numbers of HM clocks from this period. I have a catalogue reprint, but the text quality is often blurry or otherwise impossible to make out. If someone can help I'd be very grateful. Thanks very much.
