Here's a dumb question
Discussion in 'Clock Repair' started by CJo, Oct 5, 2019.
  1. CJo
    CJo Registered User
    Aug 22, 2005
    400
    Operator in an Ethanol plant. I train new operator
    southwest Kansas.
    How do I know from looking at the verge that it is an auto beat vs an adjustable verge?
  2. Uhralt
    Uhralt Registered User
    4,315
    459
    Good question. I don't know the answer but I have been exposed to very few auto beats because I mostly deal with antique clocks. I would think that the clutch in an auto beat has relative low friction compared to an adjustable one. But that's something to feel, not to see. Maybe others know more.
  3. Willie X
    Willie X Registered User
    12,468
    855
    #3 Willie X, Oct 5, 2019
    An auto- beat verge is loose on the shaft. At the tip of the crutch 7 to 45 grams pressure will rotate the verge on its shaft. It moves whenever the pendulum overswings it's normal swing.
    Manually adjusted clocks have a very stiff verge clutch. It does not normally move at all. It can be adjusted by forcefully moving it. But, it should never move during normal operation of the clock.
    WIllie X
  4. Willie X
    12,468
    855
    Missed the "looking" part. I don't think looking is going to help you much.:)
    Generally speaking, nearly all GF clocks, with large lyre pendulums made in the last 50 years, will have the auto-beat feature. Only recently has its use spread to wall clocks.
    Note: nearly all Chinese clocks have the auto-beat feature. Ha
    WIllie X
  5. shutterbug
    41,770
    916
    Auto beat verges are dependent on very short escape wheel teeth. The tips of the anchor can hit the rim of the tooth wheel when the pendulum is swinging wide, and both sides will hit the rim. The anchor will move each time it does. After the swing narrows down the anchor is not longer being interrupted by the rim and the auto-beat is complete. So .... look for short teeth. If they look "normal", it's not an auto beat.
  6. Uhralt
    4,315
    459
    Yeah, but the OP wants to find out by looking at the verge....:D
  7. bangster
    bangster Moderator
    19,511
    365
    Ain't no such thing as an auto-beat verge.
    Is what I think.
  8. Willie X
    12,468
    855
    The verge and E-wheel are designed as a set. To convert an autobeat to a manual adjust, you have to change both parts and these parts are now only available for a few movement.
    Another oddity, the factories call an auto-beat an "autobeat". But a manual adjust is called a "deadbeat". Does this mean an "autobeat" is not a "deadbeat"? Absolutely not ... they are both very much deadbeat designs. Weird huh?
    WIllie X
  9. bangster
    bangster Moderator
    19,511
    365
    So sue me. :(
  10. CJo
    CJo Registered User
    Aug 22, 2005
    400
    southwest Kansas.
    I want to thank you so much for your responses. I have learned a lot. Now I know to look closer at the escape wheel teeth and the looseness of the verge. One other thing I have seen in this forum mentioned is that the verge is not to be put into a sonic cleaner. Is this completely detrimental to the verge?
  11. shutterbug
    41,770
    916
    The autobeat verge has a wafer material sandwiched between metal parts to provide a little friction. Getting it wet ruins it, and it's hard to get tight again.
