I am working on a Herbert Herr cuckoo clock and I have not encountered this particular movement before.
I have run into a problem that I am not sure how to fix so I decided to ask all you gentlemen if you know how I might get this movement apart.
The problem I have is that the shut off lever for the ringing is connected to a shaft that runs through the movement and the activation lever for the music box on the rear of the movement is connected to this same shaft.
My problem is that both of these levers are pressed on opposite ends of the one shaft and I cannot get either one of them off with lifting levers without damaging the movement plates.
If anyone has worked on this particular movement can you please tell me how I might go about getting these levers off so I can take the movement apart to repair it without destroying it?
I am stumped and I am asking for any of your expertise in this repair?
John Murrell
John Murrell
