Helvitia Mens sub-dial automatic wind wristwatch..15 jewels full working order..Help please me to identify and put a date to movement which is 80CAL
Screwloose
Jun 13, 2020
44
35
UK England South Yorkshire
Hello,
Been a while since I've been logged in and posted on the forums. Apologies in advance for any errors at time of posting... I'm hoping you can help me, I'm struggling to pull anything up with a Helvitia sub-dial watch I have. Its CAL is 80C it's case reference is 4920975. Fully running 15 jewels automatic wind wristwatch. From my research WW2 dates and references to this period are mentioned and referred to however the CAL is often 83C not 80C...is mine an earlier model?
Thanks in Advance for taking the time to Answer and help me.. Appreciated.
Lola Parkinson
IMG_20211130_202638409.jpg IMG_20211119_202014320_HDR.jpg IMG_20211119_201951273_HDR.jpg
Screwloose
Jun 13, 2020
44
35
Hello,
Lola Parkinson
View attachment 683396 View attachment 683397 View attachment 683398
Again 10 steps Infront of myself..That's why I do like to ask here, I know I always get directed to a specific starting point to start my research, and clear signposts to start my reading. It is hard to find a suitable starting point researching a wristwatch based upon a movement ref and very little background information around the period time of production...
Found where i should be, thanks Robert Stokes for Lt.Monroes Thread "Time Capsule" reading...Ill check back soon, with the answers I'm looking for hopefully!
Peter John
Sep 4, 2018
370
185
Scottsdale, Arizona
I don’t think that’s an automatic wind watch. There is no rotor. The dial says antimagnetic. Not the same thing. Peter
Screwloose
Jun 13, 2020
44
35
Thanks Peter...I definitely have to wind it manually to start it running, can you please explain further?.. Apologies for my novice, knowledge around terminology I do need to get the basics first..I do know some information around what anti-magnetic refers to, would this alter how the watch is referenced to? Even though it is an automatic wind, to start the watch running does it get classified as another movement motion due to the anti-magnetic element? Apologies if I've not clearly explained myself..? I will pop a short video on showing the watch stationary, then wound to run ?..
Peter John
Sep 4, 2018
370
185
Scottsdale, Arizona
Antimagnetic means it is resistant to magnetic fields which would stop a non antimagnetic watch. Automatic wind means it would wind itself through the motion of your arm while you are wearing it. If you didn’t wear it and it just laid on the dresser it would soon stop. Then you would need to manually wind it again which is what you need to do to your watch to keep it running.
Peter John
Sep 4, 2018
370
185
Scottsdale, Arizona
A dictionary or Google search would help give the explanation you need.
Screwloose
Jun 13, 2020
44
35
Thankyou for the advice, appreciated. However I'm certain I've wound this watch to start it going tonight..I suppose because I don't wear the watches I mainly own, due to them obviously being men's I've not noticed the clear difference, as if probably a man would notice by wearing it..
I will use Google later, as you have suggested but while your here, id prefer to ask you a couple more questions, with answers which obviously are far more reliable, if that's ok?..I just wondered why I had to initially wind to start it going...I will read further already I'm learning so much. I'm sure other members are also reading and learning too, but perhaps like in a school classroom darnt ask the daft questions, or silly questions..I want to learn, I'm here to learn. Unfortunately when you gain such expertise in an field or area, you become a teacher to the rest, like it or not..I value your input. Google dosnt quiet respond the same.
Thankyou
viclip
Jul 20, 2018
856
624
93
Here's a link to the Helvetia caliber 80C write-up found on Dr. Ranfft's site which may be of some help:
Helvetia 80C
agemo
Apr 5, 2011
502
489
71
SAINT-NAZAIRE - FRANCE
Hi,
The caliber 80C has for origin the caliber 80 produced in 1929, it is thus the logical continuation and was produced at the end of the 40s until the 60s with some improvements.
Amicalement GG
JTD
Sep 27, 2005
9,476
939
You need to wind it to get it going because, as already mentioned above, this is not an automatic watch (i.e. one powered by the movement of the wearer). You have an ordinary manually wound wristwatch which needs winding every day.
By the way, if you are researching the name Helvetia, it is best to ensure that you have the spelling correct. In both the title and your first post your refer to 'Helvitia' which may at times be enough to confuse your internet search, or at least reduce the number of useful references you find.
JTD
171,030
1,493,239
50,083
3号缐
2,967
