Thanks for taking a look MrRoundel. I have been a long time visitor to these forums, but only recently joined. Measuring the movement in the case, it is 27mm across., so I guess this is 12 ligne?Welcome to the NAWCC's watch forums.
Can you provide the diameter across the back of the movement in millimeters? It helps narrow things down a bit. I'm guessing that it is a 9-11 ligne movement, i.e. ~20-25mm, but having a smaller range helps when checking references. Cheers.
