Help with the identity of this Cuckoo clock movement, please?
mitchf2
Dec 16, 2021
65
I need to replace the damaged strike train great wheel, so I need to identify the movement. There's a stamp on the back plate that reads "Div.Pat.u.G.M.angem."
Vernon
Dec 9, 2006
1,309
227
56
It looks like a Regula #1. Div.Pat.u.G.M.angem is patent information in German.
Vernon
Reactions: Willie X
mitchf2
Dec 16, 2021
65
Thanks Vernon,
Question: Do you know if the great wheel from a more modern Regula 25 movement would replace the damaged one in a Regula #1?
Vernon
Dec 9, 2006
1,309
227
56
Sorry Mitch but I don't. Maybe someone else can answer. What is wrong with it?
Vernon
Reactions: mitchf2
17,145
2,999
The #25 will be smaller.
There are a few catalogs around that show photos of older cuckoo chain wheels. BFI (Black Forest Imports) comes to mind. Merritt's only offers chain-wheels for the #25 and #34.
There is 'new old stock' around but knowing exactly what you are buying will be problematic.
Most of the older cuckoo chain wheels can be repaired.
Reactions: mitchf2
POWERSTROKE
Jan 11, 2011
1,642
158
A 25 wheel will not work. It's internal widths from plate to plate is 3mm less than one of those. I was going to count the teeth. But I figured it wasn't necessary after I realized it won't even fit between the plates.
Reactions: mitchf2
mitchf2
Dec 16, 2021
65
Vernon
The wheel has been mangled and the chain jumps off when it is pulled.
176,376
1,543,764
53,269
stems
1,064
3,031
