Here's a photo of a lathe I'm working on, a Schaublin 70
The feedscrew nuts are the two round things visible on the slide surface. They are a press fit into the slide rest base.
Why are there two? One idea is its some sort of antibacklash or backlash reduction arrangement (commonly done with two nuts on larger lathes) however its a puzzle. Given they are pressed in, it seems highly probable they'd be drilled and threaded in situ as it would difficult (next to impossible?) to press in while maintaining alignment of the threaded hole. Bored and tapped in situ, how would the two holes be taped out of phase (needed if they are indeed antibacklash)
Or is that just an imagined red herring.....as in maybe there are two nuts just to give a long area of engagement. I'm increasingly thinking that is the case as the other axis's slide has a long (single) nut as well.
Anybody have any insight or knowledge into this?
thanks
Mike
thanks
Mike
