Help with silver stamp/mark on watch chain....
Discussion in 'European & Other Pocket Watches' started by PJQL, Apr 19, 2017.
  1. PJQL
    PJQL Registered User
    Jun 13, 2011
    1,243
    Retired police officer
    Cornwall UK
    Hi all,
    I have an antique fetter link chain. On each and every link is a stamp...18C.
    However, it appears that it's a brass chain...but plated with...what? Silver? or white rolled gold?
    I've never come across this mark before. Does anyone recognise it or know exactly what it signifies?
    One small link surface has been previously ground to expose the bare metal beneath, presumably for an acid test..
    It's a really nice chain nonetheless...total weight is 35gms.
    Regards
    Piers
  2. MartyR
    MartyR Super Moderator
    Donor NAWCC Member
    Dec 16, 2008
    9,791
    11
    UK
    I have only seen gold chains with every link marked "18K" ... and they have all been high quality and very heavy solid 18 karat gold.
    I can only think that your "18C" mark is intended to indicate 18 carat (the European spelling) which also would mean solid gold - in this case white gold. If as you say it is actually a plated brass chain, then the marks are designed to deceive. There is no circumstance under which anyone would mark silver "18C", and also no circumstance I can imagine where anyone would try to assay a plated chain.
  3. Accutronica
    Accutronica Registered User
    Nov 21, 2016
    553
    disabled
    Texas
    I would take it to a pro and have it tested.
    Robert
  4. PJQL
    Jun 13, 2011
    1,243
    Cornwall UK
    Thanks for that Martin,
    It's interesting that the marks seem to me quite...could I say "authentic"?, in that they look 'period'..definitely a far cry from the really poor quality efforts on continental cases!
    Piers
    - - - Updated - - -
    Thanks Robert....I will if I get the chance.....but local outfits charge a fortune down here!
    Piers.
  5. MartyR
    Donor NAWCC Member
    Dec 16, 2008
    9,791
    11
    UK
    Piers, it's very easy to conduct Archimedes' test on a chain - it just involves dunking the chain in a beaker of water - and that will be accurate enough to check if it's gold. This web page explains how to go about that. You probably don't have sufficiently accurate equipment to test for silver, but I doubt whether that would be important.
  6. PJQL
    Jun 13, 2011
    1,243
    Cornwall UK
    Cheers Martin :)
    Piers
  7. John Arrowood
    John Arrowood Registered User
    Dec 14, 2001
    595
    Is the chain light in weight? There were some aluminum/aluminium chains sold in the late 1890's before the development of modern methods of producing the metal. I have a reprint of an 1897 Montgomery Ward mail order catalog which has an illustration of a similar chain; the chain was more expensive than gold plate.
  8. PJQL
    Jun 13, 2011
    1,243
    Cornwall UK
    Hi John,
    It is lightish.....35 gms....but it's definitely brass beneath the outer layer of...whatever it is.
    I'll post a close up of the 'ground' section tomorrow.
    Thanks for your input :)
    Piers
Similar Threads - Help silver stamp Forum Date
Antique silver calendar pocket watch, Help with identification European & Other Pocket Watches Apr 30, 2017
Need help deciphering silver marks on a lever fusee European & Other Pocket Watches Oct 22, 2016
Can anyone please help me to identify this European Silver Pocket Watch? European & Other Pocket Watches Apr 17, 2016
Triple cased Rob Dingley verge watch leather with silver pins help! European & Other Pocket Watches Apr 8, 2016
key wind Silver 0,935 Lion pocket watch identify help European & Other Pocket Watches Feb 26, 2016
