I recently was given a Kienzle Westminster chime clock and am puzzled about a few things which I hope someone can help with. There is a lever attached at the midpoint of the rack which can pivot at that point but whose purpose is unknown to me. There is also a small bracket with a vertical spike almost directly above the aforementioned lever whose function is also puzzling me. Finally, you will notice that there are two clicks on the chime mainspring ratchet which i presume is just for extra security?
Thanks for any help.
SC.
SC.
