Help with identification of this vintage watch?
hyperhad
Aug 19, 2010
62
Thunder Bay, Ontario, Canada
I bought this 10 years ago, at the beginning of my interest in watch collecting began. There are some hallmarks on the inside of the case, but nothing on the movement. I did some searching, and found out the following:
1918 Trench watch (sellers info)
31mm
Welded on wire lugs
9ct case (George Stockwell Sponsor)
London Import
markings from previous servicing
stepped porcelain dial, painted hour markings with minutes marked at each hour. There are no names or markings on the movement
unmarked pin-set movement
I think I see two jewels
I found some similar movement images online. This looks like some others identified as being "cheaply made". I found an image of a Junghans movement that looks similar.
DSC_1483.JPG View attachment 606980 View attachment 606981 DSC_1463ID.jpg DSC_1473ID.jpg
Reactions: Tomxhar
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
89
68
Costa Blanca - Spain
highercailber.com
Nice watch
Enamel dial with original RADIUM lume. single sunk dial.
Movement looks a pin lever escapement
Hands are not original.
London import mark, I can not make out the year mark but 1918 is a 'C' in a cartouche
Regards
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
Very cool
Movement looks very similar to a silver 1917 one I have, can't seem to find it right now but it's a center seconds jeweled lever with an odd train layout.
Actually I was trying to find it the other day to post on here to see if anyone recognized the movement.
Dan
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
89
68
highercailber.com
Very cool
Dan
Center sweep second is pretty rare in 1917, indeed I think only GALLET had?
The Ops watch does not have that
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
Actually looking again I think that one may be a cylinder.
But the train layout does indicate that it is a center sweep seconds just missing the hand.
Dan
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
89
68
highercailber.com
Dan
Yes it could be cylinder - pretty sure not a detached lever
Regards
gmorse
12,943
2,398
Hi Dan,
I think you may be right about the cylinder, but I can't see any sign of a centre seconds mechanism, the centre arbor isn't hollow.
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
89
68
highercailber.com
Hi Dan,
Agreed
No way its indirect (or direct) center sweep seconds
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
89
68
highercailber.com
It"s direct drive.
I'll have to find mine and show you.
Here's another though
Movement ID needed - 1914 Nurses Centre Seconds
Where is the center seconds hand?
I do not believe direct center seconds was invented till after 1940s (sorry I could not find my notes). Hamilton did not have till 1948!
But in 1900 to 1930 it was INDIRECT and your movement is not that.
See here
GALLET - WWI 'nurses' Sweep Seconds Wristwatch
AND HERE
GALLET - Early Centre Sweep Seconds
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
You have to look closely at the under dial of the movement in that post. If you are a watchmaker you will see what I mean.
gmorse
12,943
2,398
Hi Dan,
Yes, I do see what you mean from the WUS posting, but not from post #1 in this thread. There are two invalid attachments there, which may be the under dial work.
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
I don't know who made them, yet, pretty sure it's swiss though.
I did find similar movement that is marked Numa Jeannin.
I think the date letter looks like an "a" so would be 1916-1917.
It is the right age and luminous so you could call it a "trench watch" and it may have been used as one.
Dan
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
Also apologies if I came off as rude there.
Adam as for direct drive center seconds not being invented until the 1940s, they were used in pocket watches and so called "center seconds chronographs" (but just hack watches really) at least 100 years before that. I probably have 2 dozen.
Dan
Adam Harris
Moore NWCM Award
May 3, 2012
3,282
89
68
highercailber.com
Dan
No rudeness taken
I only talk wrist watches.
Regards
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
Well I guess I have 2 of these.
The one I was looking for had all its parts, including the seconds hand, had different simpler dial and a year later.
Still no clue of a maker and the radium is loose, so I'm not going to take it fully apart until I can deal with that safely.
Dan
15981345300147966258983241030436.jpg 15981345663308824510859528723129.jpg 15981345969282299456330564278211.jpg
Reactions: Tomxhar
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
Reactions: Tomxhar
Tomxhar
Registered user.
Sep 2, 2019
96
54
56
It's pretty obvious that all examples-even those missing their seconds hands- have centre seconds.
Only centre seconds watch dials have the outer dial markers divided into fifths of a second...:rolleyes:
There were several makers of centre seconds watches during and before WW1.
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
Well In a bad picture from Jobin (wish i had a copy but way too much money) there is an A. Schild 14''' but the picture is too blurry to see more numbers, it mostly resembles the numa jeannin and t.j.f ones (which were identical)
Tomxhar
Registered user.
Sep 2, 2019
96
54
56
Good find, and sizeable at 14 lignes!
I have a friend who has a 1909 direct drive centre seconds, he will post on his chosen site soon (hopefully!) and he tells me it is different from the examples you and the OP have posted. So several makers of direct drive centre seconds wrist watches during the earliest part of the 20th. C.
This thread seems to have gone quiet for some reason, I would have thought that there would be more interest after statements made earlier regarding the belief (or lack of) in early direct drive centre seconds wrist watches.
A shame really, I find this subject very interesting.
D.th.munroe
Feb 15, 2018
949
321
40
BC Canada
I hope he chooses the nawcc Tom:)
This is quite interesting to me as well.
I'm not sure about the others, but mine is only a 13 1/2'''.
The A.S 14''' (I found a clearer picture) only in cylinder, but is cal 403 ref 1400, was just the closest to the other less (1 or 4 maybe?) jeweled ones. Also in a book from 20 years later.
The op's appears to be a 10 jewel cylinder and mine was a 15 jewel lever and better made than the cheap a.s cylinders of that age that I have.
169,853
1,482,430
49,201
Virginiarizk
2,965
