1geo
I have a Howard Miller Grandfather Clock model 610-974, Satinwood model. I occasionally work on mantel and wall clocks but never a grandfather clock. My question is how do I remove the movement from the case. The case on this clock is a wodden frame with glass front, sides and top; its quite stricking. The movement sits on a wooden support that spands the width of the case. There are two screws in the bottom of this support piece, one on each side. It appears that If I remove the two screws the movement should be free of the case; is this correct? Or is there some other way to remove the movement. The movement is marked Howard Miller MS002. Any help would be greatly appreciated.
