Most visitors online was 1660 , on 12 Dec 2020
I suggested the new parts because there is a fairly large chunk missing from one of the pallets. If everything was aligned perfectly, and the escape wheel teeth only made contact with the center of the pallet, I guess that wouldn’t be an issue, but most of the pallet wear I’ve seen on clocks is usually off-center like this one. I’ve never had a verge that was worn this badly, and never replaced one, but they all seem to have that sweet spot where they like to ride.The bent tooth can be straightened using flat nosed pliers but the two teeth that are broken off will have to be replaced. It is possible to replace those using the dove tail insert method. There are lots of threads on this message board about dove tailing teeth in wheels. An escape wheel is more difficult but is possible. The anchor probably just needs to be polished well.
Well, the anchor is in rough shape and the replacement escape wheel does have 30 teeth like the original. If the depthing is ok and they can be mounted on the arbors easily, the new ones may work. The price seems ok. I guess I would try to repair the originals first and if it doesn’t work, order the new ones. Let us know what you do.I suggested the new parts because there is a fairly large chunk missing from one of the pallets. If everything was aligned perfectly, and the escape wheel teeth only made contact with the center of the pallet, I guess that wouldn’t be an issue, but most of the pallet wear I’ve seen on clocks is usually off-center like this one. I’ve never had a verge that was worn this badly, and never replaced one, but they all seem to have that sweet spot where they like to ride. View attachment 632561
Would love any help that I can receive. Thank youThis can be repaired to preserve original/existing material. First thing would be to re-face those two escape wheel tooth tips. It is a faff but totally doable. As above, you can dovetail in a brand new tooth or leave the stub of the tooth you have and just replace the working surface. Once you have the teeth tips replaced, they will be oversized but if you don't have access to a lathe with dividing equipment and/or a depthing tool, it can be done. If you want to explore that route, just shout and I'll do some photos and a drawing or too.
Over the years I have equipped myself for all Horological repairs that are almost always easily done on a small Lathe and Milling machine. While you may or may not be equipped with a lathe and compatible Mill, I will explain in case you are.Need to know how is the best way to repair the 2 teeth on this gear and how to repair the lever. Does anyone know where I can get one if repairs are not possible.
View attachment 632528 View attachment 632529 View attachment 632530
The matching set was my first suggestion. It needs some machining and drilling, but looks easier to me than the other methods.You might be able to pull that tooth a little longer. It's worth a try. This matching set might be an option too.
