Help with French clock maker A.F.
Discussion in 'General Clock Discussions' started by whcureton, Jun 11, 2016.
  1. whcureton
    whcureton Registered User
    Oct 27, 2010
    257
    Paradise, CA
    Hello Friends
    I recently acquired a French Brevete S.G.D.G. boulle type mantel clock.
    Time only and porcelain dial with Roman Numerals. Along with some
    other numbers and letters stamped on the roulant are A.F.
    Does anyone know if that is the makers I.D. and if so, who is it?
    One other question while I'm asking ... LOLOL ... is there a preference
    for how to reference Tran du Ly when describing a clock? For example,
    is it more proper to say "Tran # so and so page whatever" than "Ly # so and so page whatever" ... I see it called out both ways. Does it matter or is
    there a recognized protocol for this? Just nit picking.
    Many thanks!
    - Bill
  2. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,657
    142
    Aerospace Engineer (Ret.)
    San Antonio, TX
  3. whcureton
    Oct 27, 2010
    257
    Paradise, CA
    Hi Kurt
    Thank you, I saw that and I understand it to be in the case of more formal usages such
    as publication and or copyright type citations. I was asking in the context of an informal
    pointer ... like in a verbal conversation or museum specimen I.D.
    For example, "Tran #202 page 189". I guess what I really
    mean is do we use "Tran" or "Ly" as the name? Which would be the correct name to use first.
    Or does it matter?
  4. JTD
    JTD Registered User
    Sep 27, 2005
    7,652
    509
    Tran is the surname, Duy Ly is the given name. Vietnamese (and Chinese and Hungarian and some other peoples) put the family name first and the given name last.
    JTD
  5. KurtinSA
    Nov 24, 2014
    3,657
    142
    San Antonio, TX
    I, too, have seen more informal references, but I think it would be best to follow the Admin's suggestion. Not sure the original source of the reference format...possibly the author??
    Kurt
  6. JTD
    JTD Registered User
    Sep 27, 2005
    7,652
    509
    I never suggested anything other - I was simply pointing out the way Vietnamese names work.
    And there seems to be an error in the permanent post about quoting from Tran Duy Ly's books in that the last line of the penultimate paragraph talks about 'Mr. Ly's books', which is of course not correct. It should have read 'Mr. Tran's books' if the full name was not being used.
    JTD
  7. whcureton
    Oct 27, 2010
    257
    Paradise, CA
    Yes ... Tran would be his surname. I've seen others reference specific clock specimens as "Tran #whatever, page so and so" ... I think that is more "correct" than using Du Luy which is his
    given name.
    Any ideas on who A.F. as a French manufacturer might be?
  8. JTD
    JTD Registered User
    Sep 27, 2005
    7,652
    509
    Yes, you are right in your thoughts about using Mr. Tran's name.
    The initials A.F. may not be the manufacturer. It is more than possible that this was an unmarked roulant which was either finished or wholesaled by A.F. If you can post a photo, it might help but many French movements remain unidentified.
    JTD
  9. Steven Thornberry
    Jan 15, 2004
    22,100
    1,031
    Ne’er do well
    Here and there
    Thanks for pointing out the incorrect usage of Tran Duy Ly's name. It has been corrected. So far as A.F. is concerned, we have seen it many times but I don't believe it has been identified as yet. As JTD suggested, the initial may be those of the movement finisher.
  10. JTD
    JTD Registered User
    Sep 27, 2005
    7,652
    509
    Thank you Steven, appreciated.
    JTD
  11. whcureton
    Oct 27, 2010
    257
    Paradise, CA
    Thank you Steve et. al. ... we'll put on our Sherlock Holmes caps and find "A.F." ... perhaps in some off the beaten path bistro drinking absinthe ... thanks again all
