Help with damaged escape wheel in Seth Thomas no 10 for ITR time stamp clock
Discussion in 'Clock Repair' started by Jonas Sandstedt, Aug 29, 2016.
  1. Jonas Sandstedt
    Jonas Sandstedt Registered User
    Aug 29, 2016
    7
    Hello, I have a damaged escape wheel with 15 teeth and that is approximately 17 mm in diameter (see picture). It is used in a Seth Thomas no. 10 movement (see picture) that is used in an ITR time stamp clock (see picture). As seen in the first picture, two teeth are broken and the rest more or less bent. I would appreciate some tips regarding possible repair or replacement part. It seems as it is very difficult to re-manufacture this little wheel.
    best regards
    Jonas
  2. R. Croswell
    R. Croswell Registered User
    9,517
    605
    That will be an expensive wheel to have made. In the US we see No. 10 ST movements on eBay for probably less than the cost to have a wheel made. Perhaps a "parts movement" would be the way to go?
  3. shutterbug
    41,179
    799
    I don't see a repair possibility. Not enough rim to try to replace a tooth. I'd look for a donor movement too.
  4. Jonas Sandstedt
    Aug 29, 2016
    7
    Yes, the only watchmaker in Sweden I could find that was willing to at least try to re-manufacture this wheel failed; he could not find a suitalbe milling cutter.
    I had hoped a spare wheel would be possible to find in the US, but perhaps ST No. 10 is relatively rare.
    best regards
    Jonas
  5. shutterbug
    41,179
    799
    Check your private messages :)
  6. Jonas Sandstedt
    Aug 29, 2016
    7
    Thank you for all kind and helpful replies. I think I will have to consider buying a donor movement, although I favour repairing whenever possible.
    best regards
    Jonas
  7. Jerry Kieffer
    Jerry Kieffer Registered User
    May 31, 2005
    2,504
    267
    wisconsin
    Jonas
    Actually, basic escape teeth such as the wheel shown are quite simple too repair with the assistance of small milling machine as are most repairs. In this case, if all but one or two teeth can be straightened, then one or two teeth replacement is not an issue. For tooth replacement, I machine a .010" deep positioning pocket the width of the base of the tooth and high temp silver solder in a butt joint replacement tooth. Strength will equal or exceed original strength for tooth shaping and service.
    If a new wheel is preferred or required, it is still not an issue.
    It is unlikely that a commercial cutter will be found, but a single point cutter is fast and simple to make.
    I first start with a HSS lathe tool blank and free hand grind as follows per the attached photo. The right side of the cutter shown is not touched. The left side angle is free hand ground on a standard bench grinder. Only a couple of trial and error grinds are normally required for the fit shown with the same procedure utilized for the front of the cutter. In this case the spacing on your teeth are wider, but the same procedure is used to fit the cutter.
    If anyone who signed up for the NAWCC workshop WS-119 in October is watching, I will be demonstrating grinding the above cutter and cutting escape teeth. The cutter takes about five minutes to grind.
    Jerry Kieffer
  8. Jonas Sandstedt
    Aug 29, 2016
    7
    Jerry,
    Your interesting and hopeful description of repair brings me to the inevitable question if you are able to help me if I send the wheel to you.
    Do you have time and opportunity for handling this?
    best regards
    Jonas
  9. Jerry Kieffer
    May 31, 2005
    2,504
    267
    wisconsin
    Jonas
    I appreciate the consideration, but at this time I have more personal projects that need consideration than I have time for. However there are a number of advertisements for this type work in the NAWCC mart. One way to save money on this type of project is to do your own crossing if a new wheel is cut.
    And of course you can purchase a donor movement as others have mentioned.
    Good Luck
    Jerry Kieffer
  10. Jonas Sandstedt
    Aug 29, 2016
    7
    I understand Jerry, thanks.
    I will try to make repairs myself, having no panic with this little project.
    best regards
    Jonas
