Help with clock id
Discussion in 'General Clock Discussions' started by Tim S, May 18, 2020.
Thread Status:
Not open for further replies.
  1. Tim S
    Tim S Registered User
    Oct 28, 2019
    15
    Please help id this clock. It is two pieces, weights and chains fit thru a hole in top of bottom cabinet. Has a Urgos movement UW 32020 with a B or 8 after that . in bottom center of movement is 96653. Lauris on dial is raised lettering. On back of dial plate is GB or 29 or ?, depending on which way you look. Cannot find any type of mark on cabinet, but has full length hinge and magnetic latches so don't think is too old. Runs but does not chime or strike. Greatly appreciate any help, info
    cornerclock1.jpg cornerclock3.jpg cornerclock4.jpg cornerclock5.jpg cornerclock6.jpg cornerclock7.jpg cornerclock8.jpg
  2. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    2,253
    240
    Pennsylvania
    #2 new2clocks, May 18, 2020
    Tim,
    Isn't this clock the same as the clock you requested identification just a couple of weeks ago?
    What A Find...but what is it ?
    We now have two requests for the same clock on different threads. This will become confusing.
    Perhaps a moderator can merge these threads.
    Regards.
    JTD likes this.
  3. Tim S
    Oct 28, 2019
    15
    why yes, it is. But as you can see, I did not get any what I would call definitive answers in the other thread, so if a moderator wants to merge these, great, anything that might help
  4. new2clocks
    Apr 25, 2005
    2,253
    240
    Pennsylvania
    I understand your point, but it is better to just "bump-up" the older thread or add to the older thread. You will achieve your aim of having the issue back in front of the eyes of everyone, without causing confusion.:)
    Regards.
  5. Steven Thornberry
    Jan 15, 2004
    21,920
    970
    Ne’er do well
    Here and there
    I've closed this thread and suggest that any discussion continue in the thread linked tp in post # 2 above.
