Help setting time WALTHAM 14 size
PostalWatchGuy
Jul 20, 2009
67
23
I have a 14 size Waltham pocket watch and can't seem how to figure out how to set the time. I tried pulling out stem and it doesn't pull out and there is no lever to set time. Is there another way?
thanks in advance
Jerry Treiman
Golden Circle
Aug 25, 2000
6,720
2,764
Los Angeles, CA
Your watch is intended to be a stem set watch by pulling the stem outward into setting position. Here is a photo of the fairly simple mechanism. The "setting lever" within the movement shifts the rocking bar assembly under the dial into the setting position.
Sometimes these can be rather stiff to pull out and it may be that the setting parts need a touch of lubrication to work more freely.
If you are going to attempt working on this watch you should be aware that the stem of this model must be unscrewed from the "winding bar tip" before the movement can be removed from the case. You will need to insert a pin into the star symbol in the top plate -- your pin will drop into the slot at the end of the winding bar tip and lock it in place so that the stem can be unscrewed.
James Wrobel
Jan 17, 2020
58
27
60
Thanks for the tip on the winding stem. I've never heard of this feature before. Do any other models have this feature?
jjw
Jerry Treiman
Golden Circle
Aug 25, 2000
6,720
2,764
Los Angeles, CA
Yes, this was also used on the 6-size 1889 model. Look for the star in the top plate, either with a hole in it or a screw (for the same function).
Reactions: Rodney Leon
topspin
Dec 14, 2014
1,539
313
Photos - a model 1889 with star thing (from an earlier thread about the star thing),
and a model 1884 grade Hillside-with-a-screw-in-the-star-thing (from the Fattorini Challenge thread.)
Reactions: luvsthetick
PostalWatchGuy
Jul 20, 2009
67
23
I guess I need a threaded stem that fits in it.
Jerry Treiman
Golden Circle
Aug 25, 2000
6,720
2,764
Los Angeles, CA
Unless you know otherwise I would assume that your watch already has the correct stem. You need to try to unscrew the stem, as instructed in my post above (#3). Then the movement can be removed and analyzed to figure out what is not working.
This is what the stem should look like --
165,538
1,441,090
86,285
Phil Jensen
2,873
