Function Help on suspension spring
WaelFarahat
Dec 19, 2022
20
Dears,
I am in need for your support to get more information about the suspension spring for the attached 400 clock - thickness, size … etc.
it is old kinzle clock.. that is worked non adjustable but stop again, so I am thinking to change the spring and re test.
Thanks in advance.
BR
Wael
E05BBDBE-FEB1-4528-8364-7D0140CDFC80.jpeg BBB9FACC-DF2F-4757-A491-16243E4D2762.jpeg 935F543C-243D-4A48-A5A3-D340EA96F07D.jpeg 7F1F1D1D-5293-4364-9924-B23B4E515AD0.jpeg 0A2486FD-E54C-47EE-9DB2-7550F83C1279.jpeg E4DEFD89-7FC1-4A18-B9B4-1FC3D718BE40.jpeg CCC9E43A-4FC7-4255-80AB-A01BB06348D3.jpeg 15FB9058-1380-4227-88FA-5585F19B943A.jpeg
KurtinSA
Nov 24, 2014
5,955
662
San Antonio, TX
I can't help with the suspension spring size, but generally unless it is broken or severely twisted, the spring doesn't really stop a clock from running. That all comes down to cleaning the movement and main spring along with setting the beat and making sure that the escapement is correct. The picture of the full back plate suggests that the saddle bracket has been moved based on the lines that I see on the sides of the bracket. If the bracket was moved, then it might not be at factory settings.
This is a pin pallet escapement and I can see that the two pins on the anchor are not parallel to each other again suggesting that some non-standard adjustments have been made. Note that those pins are very brittle and can be broken with too much bending.
Kurt
WaelFarahat
Dec 19, 2022
20
Thnx a lot Kurt.
But what do you mean exactly with : saddle bracket ?
do yu mean this in pic attached?
if not would you please highlight for it.
Also, teh spring is not cut but it has only one twist in it.
Thnx again.
KurtinSA
Nov 24, 2014
5,955
662
San Antonio, TX
Yes, that is the saddle. One twist in the spring really doesn't present a serious issue.
Kurt
WaelFarahat
Dec 19, 2022
20
Many thnx Kurt, really appreciated.
Is there any video that help in setting the beat? also i want to lubricate, i am living in hot country KSA, and it may need to lubricate.
what is the best lubricate oil for this kind of clocks? and how to do plz ? is there a video ?
Thanks in advance.
Dells
Oct 18, 2019
1,074
350
In the cotswolds UK
Thanks Kurt
I have done one for a customer, so I am adding it for WealFarahat because it’s probably more helpful.
Dell
WaelFarahat
Dec 19, 2022
20
Thnx Dells…
Unfortunately I failed again to adjust the beat.
The pin always went to my right hand and never be in the middle to adjust the beat.
Also in both videos I notice that you mention a screw in the top that need to adjust a little, but for my clock I did not have such one.
I will upload more videos that my help to identify the issue.
Thnx in advance.
FD54AD47-E00D-4578-86C6-FFE925D47E2D.jpeg F53676CE-1D16-4AF5-BA40-8BE366F96455.jpeg B673BA91-C328-41FC-8CFD-3E011645198B.jpeg F684EEF2-978B-4CCF-8C2A-3C774B05F2D7.jpeg C9DBBD71-DB3C-402A-ABC1-72B5493855C3.jpeg 3FFDC41D-750C-4DB3-AD23-E7240C24BDE5.jpeg
Dells
Oct 18, 2019
1,074
350
In the cotswolds UK
As whatgoesaround has said some have a screw but the earlier ones like yours it has a friction fit ( sorry forgot to mention that ) you need to use a pair of pliers ( protect with card) turn it in the direction of least over swing.
I have modified an old pair of pliers but if you are careful you can do it with normal pliers.
WaelFarahat
Dec 19, 2022
20
Dears,
KurtinSA whatgoesaround Dells
I have good news.
I managed to adjust the ‘friction fit’ manually by my hands, and the TIC been is OAK.
the clock is kept working for +12 hours now with little time difference.
I will re adjust again and keep you posted.
I do appreciate your support and contribution.
WaelFarahat
Dec 19, 2022
20
Gents,
do you recommend one lubricant brand or specifications to use for such kind of clocks?
BR
Wael
Gyro Gearloose
May 23, 2022
96
Rocky Mt. High
I like the Horolover beat tool. I find it allows one to make the tiniest fine adjustments. I find myself using it a lot.
Gyro Gearloose
May 23, 2022
96
Rocky Mt. High
Yes, I've read they will twist if you over tighten it. The one I have doesn't seem to twist no matter how hard I tighten it. It came into my life 25 yrs. ago so maybe they don't make 'em like they used to. At any rate the way I use it is I loosen the top screw on the suspension saddle (it's really a tension screw) so it's fairly easy to turn the saddle. Once I have it in beat I tighten the screw before removing the Horolover tool.
KurtinSA
Nov 24, 2014
5,955
662
San Antonio, TX
Kundo clocks, and the one initially described, don't have that screw on top...Schatz clocks do. Kundos are friction fit. So, it is best to check the friction level while the clock is disassembled and see if some movement back and forth releases the friction a bit.
Kurt
Gyro Gearloose
May 23, 2022
96
Rocky Mt. High
Good point. And Kundo's saddles are top mounted making for easier access. Schatz 54 1000 day saddle screws have such a big head on them that the Horolover beat tool won't fit between the screw and the suspension bracket. It's one of my pet peeves because the 1000 day's are so touchy to get the overswing perfectly even. Using the Horolover tool would make that a lot easier.
WaelFarahat
Dec 19, 2022
20
Thanks a lot for information..
The clock is not stopped anymore after adjusting the beat as described above.
but it have little bit time decrease, so I am going to accelerate the pendulum to the left little and try again.
The decrease is around three minutes daily.
Anyway I am happy that it is working, thnx again for your precious input.
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
181,344
1,582,308
54,775
Ghostsniper
3,126
Top
