Help needed with Regula 34 Movement
richjfran123
Jan 5, 2020
23
I have an 8 Day chalet clock with a Regula 34 movement that needs replacing. Getting a standard Regula 34 is no problem but this version has a few parts that are not readily available. The shut-off mechanism is not standard and the warning levers from the movement to the music box are non standard. Does anyone know if this version of the Regula 34 can be brought off the shelf? Thanks for your help. BDC62D48-2CB9-41EF-9165-06132C436EA1.jpeg
14,373
1,606
rich,
I think that movement is available.
I'm curious as to why you are replacing it though? It appears to be in pretty good shape. I'm assuming the photo is of your clock and not 'off the internet' as many are ...
Not to much is "standard" in the world of clocks! Mark B may chime in, with more details about what is, and is not available.
richjfran123
Jan 5, 2020
23
rich,
Hi Willie
This particular movement (the picture is of the movement in question and not a copy from the internet) is In excellent condition for the most part. However it refuses to tick because the 1st and 2nd wheels on the Going have locked up solid. I managed to unjam them recently but they have since jammed again. The customer reports an accident with the weight on the great wheel with the weight having dropped from height whilst on its chain. In my opinion the the damage has been caused by the action of the weight on the chain on the great wheel and subsequent impact on the 2nd wheel. Hence a replacement. Since my post I have located a Californian site Black Forest Imports which carries the movement.
14,373
1,606
Easy to pop in new wheels. Usually, it's just the chain wheel but by all means check the 2nd wheel too.
In your case, a repair would be much easier than a replace, at a fraction of the cost.
disciple_dan
Mar 10, 2016
1,074
89
Plant City
Where is the pivot that would be in the bearing hole just above the Regula stamp? Is there something out of place or missing there?
Jim Hartog
Jan 6, 2010
794
84
Hello,
disciple dan is correct re the missing arbor in the hole above the Regula. That's where the arbor with the gear (no pinion) goes to connect T2 with the minute arbor.
Jim
167,204
1,457,065
87,366
PhilGoodew
