Help mounting movement to case
Vernon
Dec 9, 2006
835
90
This New England box clock came with the movement detached. When the dial was removed, everything just fell out. There was some small strips of wood with holes and shadow evidence on the brass movement of where the wood once was. It appears that small riveted nails held these wood strips to the brass movement. Am I right in this assumption? Do I need to remove these riveted nails and attach new wood as pictured with new riveted nails?
Thank you.
IMG_20190608_144537.jpg IMG_20190606_130915.jpg IMG_20190606_130915.jpg IMG_20190606_131025.jpg
12,774
987
Are the top 'nails' missing? Most will probably tell you to duplicate what was there. Although 'what was there' doesn't look so good, I would probably duplicate it, just to preserve the origanility and use the old holes.
These "nails" may be similar to cut tacks. Square cut nails and tacks are simply driven into an undersize hole and they bite really well. I would probably use small machine screws and nuts to make something a little more practical.
Looks like you may have 'bigger fish to fry' with that movement ...
Good luck, Willie X
Vernon
Dec 9, 2006
835
90
I agree! Here are a couple more shots one showing the upper nails.
Steven Thornberry
User Administrator
Jan 15, 2004
22,710
1,236
Here and there
I believe you are correct in your assumption. The wood strips seem to have been held on much like they are on this movement.
Unless you get lucky, you probably will not be able to re-use the original riveted nails, which leaves no alternative but to use new ones.
44,264
1,346
Another possibility is that the thin strips were used to secure the movement at the edges of the back plate. In those cases though, the wood strips usually had grooves cut into them.
12,774
987
These old movements are always interesting to me. It's difficult to figure out the reasoning on a lot of the features. On this one it looks like they were determined to get the plates up against the top of the case? And what a reach to get the MS loop to that distant pillar. Those square cutouts at the top corners means they needed that material elsewhere ... looks like they could have used it where it was too. Ha
Glad you are restoring it, Willie X
Vernon
Dec 9, 2006
835
90
Shutterbug,
I had thought about that originally but in the first picture in post 1 is a piece of wood that I believe was used and there is no slot along it's length and it's too thin to allow for it.
Steven,
Thanks for your photo. It was interesting to view.
Willie,
Yes the movement is positioned at the very top. There is even a slot in the case to allow for the ew. although it's rather deep and wide.
Thanks all for your help and encouragement
Topic related ad experiment
160,783
1,394,999
82,834
machv5
1,099
2,778
