Help identifying Ridgeway clock
Discussion in 'Your Newest Clock Acquisition' started by Happybearhome, Mar 7, 2017.
  1. Happybearhome
    Happybearhome New Member
    Mar 7, 2017
    I have had a clock that my grandparents gave me that I would like some more information on. It's a cherished gift and now that they're in failing health, I'd love to know more about it so that I can pass it along with a history to my kids one day. I know that it's a Ridgeway and it can be set to play Westminster, Whittington, OR Winchester. The last time my Grandma had it serviced (2013), she said the shop owner told her clocks that play more than one chime are a rarity. Is this true? After removing the back panel, the hardware had etched in it "Urgos, Made in Germany, 2 Jewel, and --adjusted" (I couldn't read if it was unadjusted or something else.) Under that it says UW 6/37. To the left the numbers 481566. The bell area says B122/15 R1. I'll try to attach pictures. This clock is gorgeous and sounds so pretty, it's a great reminder of my grandparents. Thanks for any help with this! IMG_3995.jpg IMG_3996.jpg IMG_3991.jpg IMG_3990.jpg IMG_3989.jpg IMG_3988.jpg IMG_3987.jpg IMG_3983.jpg
  2. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    #2 George Nelson, Mar 7, 2017
    Hi, Happybearhome,
    While I cannot answer all of your questions, I can speak to the rarity part.
    Triple chime clocks are not considered rare, but, in small clocks like yours, they are not "common". The most common table or shelf clocks that do chime play only one tune, traditionally the ever-popular Westminster notes.
    Sadly, some repairmen will exaggerate the value or rarity of a clock in order to justify expensive repair bills. I'm not at all saying that this happened to your grandparents, but it does happen.
    Also, the wording on your movement most likely says "unadjusted," common nomenclature for clocks with some number of jewels.
    Others on this board with more experience with clocks from the era of yours will be along and answer more of your questions.
    Warmest regards,
    George Nelson
  3. JTD
    JTD Registered User
    Sep 27, 2005
    3,863
    12
    Welcome to the board.
    Your Ridgeway is a relatively modern clock, I would estimate from the 1970s. This URGOS movement is, I believe, no longer in production. Western Germany on the dial also indicates a modern clock, apart from anything else. Nice to have the choice of three melodies. As has been said, not rare, but less common than those playing just one melody (usually Westminster).
    Not quite sure what information you were looking for, but hope this helps a little.
    JTD
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    "unadjusted" is a way to avoid extra tariffs. All it means is that the rate
    was not fine tuned at the factory. It is not any indication of the quality of the
    clock, one way or the other.
    The term is more related to watches that may be tested as chronometers and
    fine tuned. These would be considered more expensive and having higher tariffs.
Similar Threads - Help identifying Ridgeway Forum Date
Need Help Identifying Recent purchase - Thought to be HAC Your Newest Clock Acquisition Mar 5, 2017
Need help identifying French alabaster clock Your Newest Clock Acquisition Mar 4, 2017
Help identifying this clock i inherited 20 years ago Your Newest Clock Acquisition Jan 22, 2017
help identifying and dating longcase clock Your Newest Clock Acquisition Jan 8, 2017
Need help identifying Ridgeway Grandfather clock Your Newest Clock Acquisition Jul 22, 2015
