Help Identifying Miyota Movement
Discussion in 'Watch Repair' started by luvaduck, Dec 8, 2016.
  1. luvaduck
    luvaduck New Member
    Dec 8, 2016
    Can anyone out there help me identify the part number for this Miyota movement please. I want to replace it but can't see any identifying marks.
    Thanks in advance for any help
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    #2 roughbarked, Dec 8, 2016
    Looks pretty much like a stock standard 2035 but there were many variations.. Don't quote me.. They aren't expensive to buy as new replacements but they are also one of the few standard movements that have lasted the ages and are repairable.
    I've simply cleaned all the replacements my predecessor replaced(that weren't otherwise rusty or something.. ) and they are as new.
    Edited to say... It really would help if you started your measurements at zero. It could help my posts make more sense. I don't actually know the caliber of this ligne, off the top of my head but I can probably find it in the old replaced movements boxes, if I have time tomorrow.
  3. luvaduck
    luvaduck New Member
    Dec 8, 2016
    Thanks for your quick reply. I've attached a pic starting at zero on the scale. The part you mentioned looks the same. I just need to confirm the sizes. Should there be any identification marks anywhere? IMG_5112.JPG
  4. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    Identification marks?
    If it says Miyota, there should also be a number, such as the one I mentioned. One could probably surmise that otherwise, it possiibly wasn't made by Miyota.
  5. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    1,949
    Doctor
    Linköping, Sweden
  6. WATCHBREAKER
    WATCHBREAKER Registered User
    Dec 2, 2014
    85
    Watchmaker
    Edwardsville, IL
    its a standard 2035. they are less than $5.
  7. luvaduck
    luvaduck New Member
    Dec 8, 2016
    Thanks everyone, I've ordered the 2035
  8. oilseed
    oilseed Registered User
    Sep 27, 2009
    22
    Procurement Engineer
    Meridian, Idaho
    For future reference (on this movement and any other movement, anyone is looking to identify)
    Jules Borel has a complete ON-line catalog, with pictures and specs for all the movements.
    http://www.julesborel.com/Catalogs%20&%20Flyers/Movement%20Catalog%202014.pdf
    (Miyota starts on page 50)
    as for this being the 2035, that's not quite a positive conclusion (based solely on the picture). yes, the 2035 is common, but there are variants which allow for slightly different minute and hour hand posts (2034, 2036 and 2039 for example). so, depending on what 'hands' were on your watch, you would need to get the correct 'variant' so the hands would fit properly.
    also, you did not mention if your watch had a sweep second hand (or not).
    if not, then the 2025 would be correct. (yes, and before I get flamed, the 2035 would also work without the sweep second hand installed.) but if you're going to do it right, then...
    sorry if I'm being 'too' complicated.
    cheers
  9. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    There are different heights of these movements, ie: longer canon pinion, hour wheel and 4th wheel. There are date versions and day date versions. There are 0 jewels and 1 jewel models. There are also the "G" models which are easily distinguishable by being gold coloured.
  10. oilseed
    Sep 27, 2009
    22
    Meridian, Idaho
    Yes, my error. I stand corrected. thank you.
    so with this info, the original lister needs to know what these subtle differences are so as to obtain the correct movement for his repair.
Similar Threads - Help Identifying Miyota Forum Date
help identifying jeager cal 352 part Watch Repair Mar 22, 2017
Help Identifying Watchmakers tools Watch Repair Sep 5, 2016
Help identifying a pocket watch movement Watch Repair Feb 27, 2016
Need help identifying stopwatch movement Watch Repair Dec 4, 2015
Other PW Help with identifying this tool Watch Repair Apr 16, 2015
