I've had these for over 30 years. No clue what they are used for. I have a nice old Marshall watchmakers lathe that I mainly use to polish pivots and replace the occasional broken pivot. It uses 8mm colletts. These were mixed in with the box of colletts when I bought it. Thanks for any help.
In the next picture, you can see that the center shaft has a flat section for tightening the clamping lever. If you loosen the clamp several turns, then the shaft is free to turn. Also in the other pictures you can see a small hole at the top of the shaft. What is that for
ABOVE...JUST FOR SIZE COMPARISON NEXT TO 8MM COLLETT
AND NOW THE SECOND ITEM IN QUESTION...first picture is assembled, second shows the 2 parts, and the lower piece is 8mm
