Help Identifying Hamburg American Clock Case
Johnretired
Oct 12, 2020
11
I inherited a wall clock that appears to be a Hamburg American model as the movement bears the HAC trademark (photo) with "42" above it. However, it's unclear to me whether the case is HAC or some other manufacturer. There is no label on the case; there are some handwritten numerals on the case back but think those are of little relevance. There is a small embossed plate (photo) below the pendulum.
- the embossed plate has an upward pointing arrow between the numerals; maybe consistent with arrow use in trademark?
- is "42" the movement model number? I cannot find any other numbers on the front or back plate.
- the suspension arm bears the initials D.R.P.
- the dial is approximately 7" diameter.
Looking through the HAC thread, I learned these clocks types could be ordered with various tops. I'm unsure whether the horse is original as it seems a bit out of scale.
Any help in identifying this clock case and approximate age is greatly appreciated.
Thanks.
John
IMG_4368.JPG IMG_4397.JPG IMG_4405.JPG IMG_4406.JPG IMG_4407.JPG IMG_4408.JPG IMG_4410.JPG IMG_4411.JPG IMG_4412.JPG
new2clocks
Apr 25, 2005
3,595
570
Pennsylvania
The manufacturer of the case will most likely never be known.
Most German clock makers purchased cases from independent cabinet makers. Most German clockmakers also sold "loose" movements to the trade (retailers, wholesalers, etc.), so a wholesaler or retailer would purchase these movements and case them in their own cases. And some German clockmakers also produced their own cases. And some German clockmakers did all of the above. :)
DRP is an abbreviation for Deutches Reich Patent, meaning that the part is patent protected under German law.
The clock may be listed in an HAC catalog and someone may have a copy of that catalog. If so, they may be able to provide a name for the clock.
The style of clock is a free swinger and by looks I would estimate anywhere between 1895 to 1910 or so based on style and the period that free swingers were popular. HAC did not leave many clues to help date their clocks.
Regards.
Johnretired
Oct 12, 2020
11
Thanks much for the reply and information. Do you know if the embossed plate serves some purpose or just an embellishment? I've noticed similar plates on other clocks as well (II I I II).
JTD
Sep 27, 2005
9,039
835
This is called a beat plaque or beat plate. Theoretically it helps when you are setting the clock in beat, you can see when the pendulum is hanging exactly vertical.
JTD
168,225
1,467,140
48,173
hallmawfuedu
2,955
