Help identifying grandfather clock.
Discussion in 'General Clock Discussions' started by LanceMoody, Mar 19, 2017.
  1. LanceMoody
    LanceMoody New Member
    Mar 19, 2017
    I got this clock from my wife for a birthday present last year. I guess they were a little rough moving it and when it got to the house I had the clock and some misc pieces. I figured before attempting anything with it that I should get an ID. I took the pics of anything I thought was relevant but willing to take more. My hope is that I can see if im missing parts and hopefully reattach whatever fell off. Thank you.
    17379779_10154743002924221_1095382844_o.jpg 17407852_10154742999274221_199722251_o.jpg 17407934_10154743002499221_1674082512_o.jpg 17431041_10154743001789221_1773005366_o.jpg
  2. harold bain
    Donor NAWCC Member
    39,958
    Pictures of the movement, and your "spare" parts would help.
  3. LanceMoody
    Mar 19, 2017
    I hope this is what you need. The other spare part was the chimes and I think I attached those right, even though I probably should have waited I just got excited.
  4. harold bain
    Donor NAWCC Member
    39,958
    Well, you have a broken suspension spring, a leader and pendulum among your spare parts. The clock will not run without them. I suggest you find a qualified repairman to fix this for you.
  5. LanceMoody
    Mar 19, 2017
    I will look into it, besides what she spent to buy it, and repair cost, do ya think it would be worth repairing?
  6. harold bain
    Donor NAWCC Member
    39,958
    It appears to be a good quality movement, worth restoring.
  7. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    The clock is a Colonial model 1889. It was most likely made right
    around the time when they stopped using the 4 number
    model numbers. I would suspect it was made around the late
    1960's
    The 239 may have been a lot number or the movement option.
    It has what we call a bim-bam strike movement, although the
    rods are called chime rods, it is not a chime clock.
    Colonial did not make the movement, although they often had their
    stamp on the movement. They contracted a number of different
    German manufactures for movements.
    The case was made an assembled in the USA in Zeeland MI.
    The clock will need servicing. Don't be surprise if it cost more
    than you payed for the clock.
Similar Threads - Help identifying grandfather Forum Date
Help identifying the maker of this German Grandfather clock General Clock Discussions Oct 10, 2017
Need help identifying grandfather clock General Clock Discussions Jul 7, 2016
Help identifying a German grandfather clock? General Clock Discussions Apr 26, 2016
Help identifying Grandfather Clock General Clock Discussions Apr 15, 2016
German grandfather clock with matching cabinet need help identifying and valuation General Clock Discussions Jan 4, 2016
