That's quite interesting. I can't think of any Austrian cuckoo case makers at the moment, and I don't recall ever seeing a cuckoo case marked like that. But I believe the movement is German, whoever the case maker was.It has "made in Austria" on the dial.
You can just see it, even in the uncleaned photo, if you click on it and it enlarges. You can see the word AUSTRIA between the hands on the innermost circle of the dial, just above the hand shaft.dial that states Made in Austria.
JTD,You can just see it, even in the uncleaned photo, if you click on it and it enlarges. You can see the word AUSTRIA between the hands on the innermost circle of the dial, just above the hand shaft.
As for the extra holes, they seem to be exactly in a radius line with the legs of the present movement. I wonder if the first holes got worn and enlarged and so, instead of plugging the worn holes, the owner just moved the legs outwards to unused wood.
JTD
JTD,
Your eyes and / or computer are better than mine.
I also thought of moving the legs as an explanation, but could not tell for sure if the legs were flexible or fixed in place.
Regards.
