Thanks Graham. I believe I have the correct hour and minute wheel(s). Attached are two more shots with the two minute wheels I have, as well as a close-up of the center wheel arbor ( these two minute wheels were in a container with the movement and two incorrect cannon pinions). It appears that the cannon pinion is pressed on one end and a collar is pressed on the other, sandwiching the quarter snail mechanism. What is this watch, is it valuable, and are cannon pinions, cases, dials and hands readily available? It actually runs fine, which is very encouraging, so I am weighing selling vs. restoring. But first I want to at least know what it is and if it's value justifies the effort/cost.Hi jwatches,
The quarter snail, (blue) is there, as is the quarter rack (black), but the minute wheel which should fit on the post (green) is missing, as is the hour wheel which should fit over the cannon pinion (red), but I'm afraid there are some teeth missing from the pinion in the centre of the red circle. This drives the minute wheel as well as the quarter snail and has a finger underneath it which indexes the hour star wheel next to it, so in a repeater this part is more complex than the one in a plain watch and accordingly more difficult to find a replacement if it's damaged.
This one is quite close, but it looks like the center bridge is straight and mine is curved. Likel;y LeCoultre, but maybe a different caliber?Looks like a LeCoultre caliber.
bidfun-db Archive: Watch Movements: LeCoultre 31, 19'''
www.ranfft.de
