This movement is from a Camel Back clock of some sort. The clock came in with a replacement dial with no name, a replace back door with no label, and there are no markings anywhere on the movement.
I think it is a German movement with 1.8mm thick plates and all of the pivot holes have bushings. There are a couple that are a bit like an oval triangle that I assume are replacements. I have never seen a bushing like this, but it seems ok.
All of the wheels seem stamped since there are little ridges of brass still on the inside edges on one side.
The dial is 7 inches and there is a large, very fine brass coil gong.
A couple of features new to me are how the winding arbors are fitted to the main springs. The arbors fit through a tube that goes through the barrels and a pin is inserted in the arbor to fix it to the tube which has the hook for the spring. The time side has the normal orientation but the strike side is reversed which will make putting the sleeve in the barrel a bit tricky.
thanks for your help
tom
tom
