Help ID Vienna Regulator
gintarasb64
Oct 1, 2012
228
26
Lithuania
Hello,
Looking for help to identify Vienna Regulator clock. Movement us unsigned, just serial number on back plate. Austrian style mounting bracket and unusual gong .
Best regards
Gintaras
20210415_081443.jpg 20210415_080942.jpg 20210415_081358.jpg 20210415_081031.jpg 20210415_081047.jpg
svenedin
Jan 28, 2010
1,264
236
Surrey
I can’t ID your clock other than to say the keyhole type fixing often suggests Austrian (but not always). What I would say though is it’s been extensively bushed without re-cutting the oil sinks leaving the bushes proud of the oil sinks. If others cannot ID your clock from your existing photos it may help to see the movement with the dial removed. Case may have lost its top (if it ever had one).
jmclaugh
Jun 1, 2006
5,344
247
Devon
Typically Resch marked the serial # on the backplate, the mounting bracket and the top of the pendulum rod which this one has though the movement # differs to the one elsewhere. From recollection Resch mounted the gong on the backplate not the case though that's based on ones I've seen.
I think it should have a pediment.
gintarasb64
Oct 1, 2012
228
26
Lithuania
Thank you for your comments.It is shame to me I did not recognized Resch. The unusual gong mislead me. I think that gong in this clock is not original, installed later. I compared this movement with other Resch movement and they are similar.
Best regards
Gintaras
jmclaugh
Jun 1, 2006
5,344
247
Devon
I have seen a Resch online that used a rod not a gong, the rod was attached to the case not the movement.
Reactions: gintarasb64
166,351
1,449,391
86,827
kawasemi
2,911
NAWCC Forums Rules by Steven Thornberry
