help id this little beauty
Discussion in 'General Questions' started by dg23662, Mar 17, 2017.
  1. dg23662
    dg23662 Registered User
    Jan 26, 2012
    I just picked up this little beauty from an antique mall and I know it is not too old but I was wondering about the year it was made. It is a Zaandam wall clock. I have looked it up on the computer and found that most of the newer ones (70's and 80's) appear to have a Hermle movement installed, and with this not having one it has me wondering what year it was made. There are no marking on movement or case to help. I have started cleaning some of the brass work and it is looking better every day. I also need to but a pendulum which I found at Timesavers.
    Attached Files: Download all post attachments
Similar Threads - help little beauty Forum Date
Resetting Hands to Coordinate with Strike on Chelsea Banjo Clock - A little help pls General Questions Feb 7, 2017
Think this is a Dold, but not sure. A little help? Thanks! General Questions Dec 17, 2015
A little help with info about Mauthe General Questions Sep 24, 2015
A little suspension spring info needed-help! General Questions May 23, 2015
Need help identifying a cheap little movement General Questions Mar 21, 2015
