Help Id this clock.
BIG D
Mar 2, 2004
488
Memphis Area, TN, USA
I recently acquired this clock. It is obviously a married piece. The movement and repro face are marked Waterbury. The movement drop is much too long for this case and it has been "rigged" to work.
I would like to know is this originally a waterbury or some other brand of case if any one can help. The distinctive feature (and one I like) on this case is the side pieces at the bottom. They are "3-d" carved, Not stamped flat boards. Any help will be appreciated as usual.
harold bain
40,851
170
72
Hi, Don. The side of your picture is too dark to make out, but my first thought was "Ingraham", so I checked my Ingraham book, and found the "Arctic" with an identical top piece, and base.
BIG D
Mar 2, 2004
488
Thanks Harold! What year is that catalog? Just checking approx date.
Here is another pic using a flash of the side pieces. maybe it will help.
You folks really make this board an assett.
harold bain
40,851
170
72
Don, it is one of the 'Ocean line' from 1915. It came only in oak. Side pieces are completely different on yours. Can't see your glass well enough to compare it.
