Hi Everyone,I hope You are All well,
I have been given a Clock Movement,which has been part dis-assembled.Which I am hoping I will be able to Practice on.What I would like to ask is,how would the two Wheels which are still attached to the clock plate,be taken off.Also it looks to Me,with My very limited knowledge,as if the Pivot has been broken off on the larger Wheel.Firstly,is that correct and secondly is that fixable,or would that be above My skill level.I have been told it is a H.A.C. Movement ,if that helps.Thanking You in Anticipation.
Phil
Phil
