Help find a case for movement (what size on my measurement?)
Discussion in 'American Pocket Watches' started by Siyuan Gu, Mar 20, 2019.
  1. Siyuan Gu
    Siyuan Gu Registered User
    Student Member NAWCC
    Feb 8, 2017
    24
    Dear all, I would love to find a case for a movement with its dial.
    I think obtainable American pocket watch standard size case is the best suit for this project (I live in US).
    With careful measurement (see attached drawing), I found the dial is 45mm and movement caliber at 44.4mm.
    Dial thickness is 1.9mm and total thickness with dial+caliber =9.2mm
    What size, such as 16, 18s etc. is the best hope to host this movement? I will likely look for one on ebay then.
    If you have a case or display case which can fit the movement, appreciate that you message me.
    Thank you very much for help! Best regards,
  2. Siyuan Gu
    Feb 8, 2017
    24
    By the way, the movement is a key winding with bridges. Yet the key point is to find something to protect dust and moisture and easy to carry.
    It is okay if the case has stem or not. It is okay that the lid has no key hole.
  3. luvsthetick
    luvsthetick Registered User
    Mar 31, 2010
    720
    558
    93
    retired
    Georgia
    Based on your stated measurements your movement should fit a 18 size case. 18 size movements measures 44.8 mm with allowance for the dial.
    I would find an inexpensive KWKS case on ebay and see if you are satisfied with the fit. You could upgrade the case later if desired.
    Hope this helps.
  4. Siyuan Gu
    Feb 8, 2017
    24
  5. Les harland
    Les harland Registered User
    Apr 10, 2008
    1,301
    93
    Hertfordshire England
    Keep an eye on Ebay and any other auction sites you know
    If you are looking for a silver case you will have an advantage over "scrappers" as you will not need to sell what you buy to make a profit
  6. NC Plumber
    NC Plumber Registered User
    Jan 15, 2011
    368
    12
    Daveswatchparts.com has a nice 18s key wind coin silver case up for sale.
  7. topspin
    topspin Registered User
    Dec 14, 2014
    1,304
    84
    A photo (front and back) would be useful.
    Yes, in principle from those measurements it ought to be an 18s.
    Broken 18s keywinds in sturdy silver cases are still plentiful & affordable over here.
  8. Siyuan Gu
    Feb 8, 2017
    24
    Hi, thank you to you all :)
    And thanks to @NC Plumber I learnt where to find a bulleye glass of a particular size, instead of shopping several with size that I don't need.
