Help About this Regula 701 Movement??
bangster
19,969
499
Any of y'all care to give me some kind words about the Regula 701 movement before I tear into it? This is the first one I've run into. That strange business with the music box looks worrisome
Any hints or wise sayings you can give me, before I plunge into grief? What sort of troubles am I likely to encounter, etc.?
bangster
harold bain
40,853
178
72
Make sure you understand how it works before you take it apart. It is relatively simple, a better design than most musical cuckoos.
LaBounty
NAWCC Life Member
Aug 29, 2002
3,448
56
Mitchell, NE
www.abouttime-clockmaking.com
These have the usual problems with plated pivots but they also suffer from a major depthing problem high up in the music train. I can't remember exactly but I think it is between 4th and 5th gears.
Also, don't loose the small ball bearing inside the lower worm bearing hole when you disassemble the fly bridge. The only thing holding it in place is the arbor.
Adjusting the music warning hook is a real pain too. I adjust it rather deep so it just nips the warning pin as the music is playing. If it is adjusted so the hook clears the pin at any point other than warning, the music will sometimes skip warning and play during the cuckoo process.
I believe these movements are still available...
46,713
1,912
Looks like someone might have modified your fly. I've seen two different styles though, so yours might be a third :)
bangster
19,969
499
It looks a lot like the AM72/12 movement in the BFI catalog, which appears to have tall "wings" similar to these.
bangster
bangster
19,969
499
Thanks y'all, especially LaB, for the input. I shall put it to good use.
bangster
166,182
1,447,722
86,719
Mark21
2,883
