• Upcoming updates
Heinz Jauch BPH?
Jeff C
NAWCC Business
May 26, 2005
2,123
Seven Fields, Pennsylvania
I'm wondering if anyone has record of the BPH for this Jauch WM chime movement. I can't seem to narrow it down in both the Time Trax and The Clockmakers Beat Book. I'm testing at 4023BPH but its too slow.
Markings on the rear plate: (not sure what they might indicate)
Left Side- 77 774 Right side- 289002
Thanks for your help.
49,686
3,032
Jeff - set your meter to count beats, and disable the strike. Take off the pendulum (if it will run without it). Now watch the minute hand. When it touches the number 10, start the counter. When it touches the 10 again, stop it. The recorded count will be the beats per hour needed.
You can leave the pendulum on and let it run for several hours if you want. Average the number of beats by the hours run. That would give you a very accurate BPH. The accuracy of the clock makes no difference for this test. It will be right regardless. :)
Smudgy
May 20, 2003
2,874
26
It's possible that the 77 is BPM, which would translate to 4620 BPH.
Jeff C
NAWCC Business
May 26, 2005
2,123
Thanks for the replies. Shutt I have the Time Trax 185, I don't believe I have that feature. I kind of wish I had that option though.
As for the 77 I thought that too but the 4620 would be too fast. Right now I'm at 4053 BPH and looking at it this morning it seems pretty close. A bit later I'm going to verify this with my atomic wall clock I use in my shop.
I probably should have counted the wheels when I overhauled it, my mistake:bang:
180,041
1,570,599
54,357
Erdetenhjort
911
3,090
