Heco 400 day losing ~4 hours per day
Discussion in '400-Day & Atmos' started by earl08, Apr 16, 2018 at 7:56 AM.
  1. earl08
    earl08 Registered User
    Jun 29, 2016
    Computers
    Maryland
    I have a coehler 400 day. Suspension spring on it had a kink. .0025 in spring on it has now been replace. It is losing 4 per day, I suspect the spring that was on it is incorrect. Can someone tell me what spring should be on it? thanks in advance.
  2. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    2,073
    Aerospace Engineer (Ret.)
    San Antonio, TX
    According to the repair guide, it should have an 0.0032" spring.
    Kurt
  3. earl08
    Jun 29, 2016
    Computers
    Maryland
    thanks Kurt. kinda figured it was not right. proably why it would up in the family's storage. FWIW I did check the spring size with 2 different tools digital caliper and micrometer.
  4. KurtinSA
    Nov 24, 2014
    2,073
    San Antonio, TX
    I've not gotten the second handshake on how to properly measure the thickness of a suspension spring and I have three micrometers and a digital caliper (typically not enough resolution). I basically trust the packages I get for being the stated size. If the clock doesn't keep time within regulation, then I have to figure out what spring to go to next. The best situation would be that if it were too fast, it's possible to thin the existing spring to slow it down...I've been fairly successful when having to do that. If the clock is too slow, all that can be done really is to go with a thicker spring.
    Kurt
  5. Harry Hopkins
    Harry Hopkins Registered User
    NAWCC Member Donor
    Nov 16, 2011
    333
    10
    Retired Instrument Technician
    Mason, IL
    I agree with Kurt that .0032 is correct for your clock but from my calculations a jump from .0025 to .0032 would result in your clock running approximately 11 hours per day faster. I am guessing the kinked spring you measured was not a genuine Horolovar spring. The Repair Guide spring sizes will only work for the Horolovar springs so keep that in mind when ordering your new .0032 inch spring.
  6. shutterbug
    shutterbug Super Moderator
    35,901
    124
    For every .0001" of thickness change, the rate will increase (or decrease) by 4 minutes per hour. Thicker runs faster.
  7. Tim Orr
    Tim Orr Registered User
    NAWCC Fellow NAWCC Member
    Sep 27, 2008
    585
    95% retired from the ad business.
    Boulder CO
    Good afternoon, Earl!
    Pretty far out there, but given it's such a huge time loss, might it not be the case that the escapement is "fluttering" so badly that the clock is actually gaining 8 hours instead of losing 4? As Harry suggests, the "right" spring ought to make the clock run 11 hours a day faster than it appears to be running now.
    Best regards!
    Tim Orr
