Head scratcher here....Need ID of make and such
comet61
Aug 7, 2021
27
60
Inquiring for a person who just acquired this clock. Looks to be very high quality build and the movement is one I've never seen before of that design. In the lower left corner of the movement you can barely make out the word "Patented" 1880's something. No other mark could befound including a tag or such. Owner stated that it will run for 5 minutes then stop dead. Doesn't know if the chimes work at all. Any insight would be greatly helpful.
2lledzuaack71.jpg 32a28zuaack71.jpg 868vtzuaack71.jpg jxerozuaack71.jpg ojpml0vaack71.jpg x6wfi4vaack71.jpg
T.Cu
Sep 26, 2020
212
Hi, your friend might be the lucky owner of an Ansonia "Virginia", unless I am mistaken. Impressive clock!
Andy Dervan
Gibbs Literary Award
NAWCC Star Fellow
Oct 23, 2002
2,929
133
"Patented" may or may not mean anything as companies sometimes stamped it on plates. If it had a patent date it might be believable.
It is time and strike movement on a gong typical for the period - not chiming.
Andy Dervan
Steven Thornberry
User Administrator
Jan 15, 2004
23,998
1,688
Here and there
In the first post, comet61 said that one "can barely make out the word "Patented" 1880's something." That seems to indicate that a date was stamped on the plate. Two good possiblities come to mind. First US259505 of June 13, 1882, which seems to be the most commonly found patent date on Ansonia movements. I prefer, however, US339867 of April 13, 1886, which seems applicable to this movement. The patent drawing even includes a representation of the same movement shown above. I know of another (I think, remotely) possible patent, but one of the two I mention here are, in my estimation, more likely.
Carl Bergquist
Oct 27, 2010
295
39
79
Southeast Wisconsin
I have a couple of Ansonia movements with that "fancy" plate design. T.Cu has it right, the case is the "Virginia" dated 1904 in Tran's book. It could be purchased with several options including a statue. $72.50 in 1904 was at least a few months wages so it is not a common model. I don't think the movement is special, not bad just the run of the mill Ansonia visible escape movement.
169,733
1,481,419
49,125
Nersinho
2,965
