Harbor Freight ultrasonic cleaner
Discussion in 'Clock Repair' started by Schatz70, Oct 19, 2019.
  1. Schatz70
    Schatz70 Registered User
    Oct 5, 2019
    164
    I found this Harbor Freight 2.5 L ultrasonic cleaner priced at $79.99. Based on the user reviews people are using this mostly for gun parts, lawnmower carburetors and jewelry. Would this be suitable for clock parts?
    2.5 Liter Ultrasonic Cleaner
  2. R. Croswell
    R. Croswell Registered User
    10,332
    867
    I have one that I use all the time and have been using it for maybe 15 years or more, can't remember. Looks like the new one has larger control buttons and there is no way to know if the insides are the same. The size is OK for most clock movements but not large enough for really big grandfather clock movement plates. You should never clean a movement without taking it apart and this little US is fine for parts and most movement plates. Another advantage of the small size is that if the solution becomes contaminated you just dump it and it doesn't cost a fortune to refill. It is fairly low power so don't overload it. I find that about 8 minutes does a good job. If I were running a high production shop, yes, I would go for a larger more powerful unit but this one suits me fine. I'm thinking of getting a second one.
    Schatz70 likes this.
  3. shutterbug
    43,465
    1,236
    I have often said that if you are going to get equipment, get the best you can afford. Otherwise you'll have one or two laying around representing the wasted money.
    I tried smaller units but finally decided to bite the bullet and buy a 4 gallon cleaner. Haven't looked back.
    breeze and Schatz70 like this.
  4. bruce linde
    bruce linde Technical Admin
    6,780
    822
    oakland, ca.
    love mine... but sometimes wish i had a larger one when those big plates can't be completely submerged in solution...
  5. bangster
    bangster Moderator
    19,755
    414
    Me with RC and Bruce. The times when I thought I might want a bigger one are scant. Does everything I want it to.
  6. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,575
    121
    retired educator
    Greenfield, Nova Scotia
    There is no heater and no drain if that is important to you. I have one of these, it is now in a closet. Not really good enough for my needs. I bought an L&R and there is no comparison, the L&R does a much better job.
    Ron
  7. Vernon
    Vernon Registered User
    NAWCC Member Sponsor
    Dec 9, 2006
    711
    76
    The HF. 2.5L has served me well for many years and still works. Recently, I purchased a new 10L with heat from flea-bay for about $50 more than what your looking at. Now I can put both time and strike wheels in at the same time. It will also handle the larger plates. I'm a hobbyist but have been on it long enough to know that I will never tire of it and want better tools.
  8. R. Croswell
    10,332
    867
    The HF unit does have a heater but the temp is preset. The heater can be turned off. Indeed there is no drain but it is so small and light it can just be picked up and dumped. Not for everyone, but if one is OK with the size it is an adequate little cleaner.
  9. bangster
    bangster Moderator
    19,755
    414
    Correction: It does have a heater. No need for drain; just pick it up and pour it out.:emoji_grinning:
    Bob beat me to it. :(
    Rockin Ronnie likes this.
  10. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    3,318
    377
    Science teacher, writer
    Lancaster, Ohio, USA
    I started with one of the Harbor Freight units and it worked splendidly. But I really wanted a larger one, so I bought the following Oriental creation:
    New 6L Ultrasonic Cleaner Stainless Steel Industry Heated Heater w/Timer 806808177162 | eBay
    Actually, I believe I bought the 10-liter version of this--there seem to be dozens of these at eBay. Mine has performed flawlessly for years, thought it's becoming encrusted with icky clock crud. Note, however, that a larger-sized tank may tempt you into doing intact cleanings of movements, a practice strictly prohibited in Leviticus.
    I clean all sorts of stuff in mine, some of which pertains to clocks and some of which doesn't. (It did a marvelous job on wind-up phonograph frame parts a couple of years ago.) I keep it filled with not-necessarily-very-clean Zep Fast 505 industrial degreaser. Immerse anything in the tank, turn on the heat, set the timer to a maximum of 30 minutes, and start the thing a-buzzing. It'll clean anything and damage nothing.
    M Kinsler
