I've asked this question before and there never seems to be a definitive answer on this problem. On an older her eight day Herr from the 50s the hands are off by about a minute or two when it strikes I see no way to correct that. I have adjusted the lift lever a couple times with no real solution if I tighten the inner nut it helps a little bit. That's the first problem the second thing is the hands seem a little stiff when you turn them, not super stiff but more than I personally like. I've tried new nuts doesn't really work the movements been completely overhauled. One thing that I noticed works is if you turn the outer nut upside down it seems to work properly is this a valid way to cure this problem?
P.s there is also a very thin brass washer with a square hole when I received this. What is the correct spot for it? Between the two nuts? Between the cannon and minute hand, between the hand and inner nut? It looks homemade, not sure, I've seen it once before
