hammer on the rise / hammer not droped.
gordon
Mar 7, 2007
233
Canton, Michigan 48187
Hello All
I have a tallcase with a Kieninger MS 002 movement with hammers on the rise and one hammer not geting dropped.
Could the pin barrel's lift cams have been shifted? If so how could they be re-alined
This movement is a simple westminster chime only. Each of the 4 cams on the pin barrel are marked 1-4. One is on the outside and 4 is on the inside next to the rear plate. After the quarter hour the hammers drop in decendig order (4,3,2,1).
On the quarter hour chime #4 hammer is on the rise. For the half hour and 3/4 hour,and the hour chim # 3 hammer is on the rise. The worst thing is at the end of the half hour chime hammer #1 does not get dropped. If the hammers on the rise are eliminate I have more hammers not getting dropped at the end of their chime sequence.
I have shortened the chime's warning pin travle to only about 1/4 turn of warrning run. Still the above hammers are on the rise.
Thank you in advance for your help.
Gordon
bangster
20,017
544
Sounds to me like the pin barrel drive gear needs adjusted.
Tom Kloss
Dec 5, 2003
1,882
N.E. Pennsylvania
Hi Gordon
Bangster is correct. When chime sequence has completed none of the hammers should be on the lift or held up. They all should be dropped to the neutral position.
T.J. Kloss :cool:
bangster
20,017
544
After one of the chimes is completed...
Loosen the drive gear setscrew.
Turn the gear (free of the shaft) until all hammers are dropped.
Re-tighten setscrew on the shaft. :thumb:
bangster
Mike Phelan
Dec 17, 2003
10,339
130
West Yorkshire, England
... and check on all four quarters - pin barrels are sometimes not that accurate.
Put the warning run time back to where it was.
gordon
Mar 7, 2007
233
Hello
If I move the pin barrel one way their are hammers on the rise when the chime train goes in to warrning. If I move the pin barrel in the other direction I have more hammers not droped at the end their chime sequence.
Never had this problem befor when setting up dozens of triple chime movements.
Gordon
bangster
20,017
544
Ooh, that's weird. Maybe some bent hammer-tails? Are the pin wheels assembled in the right order? Maybe needs a shorter warning run? Nah, you tried that. How does the train lock at the end of the run? Hook onto locking cam notch? Worn pivots in there somewhere? (not sharp enough lock)?
Hmm. Can we see a picture?
gordon
Mar 7, 2007
233
Hello Bangster
Yes, it's weird. Maybe some bent hammer-tails? No the hammer tails are stable. Are the pin wheels assembled in the right order? I beleave they are. Maybe needs a shorter warning run? Nah, you tried that. How does the train lock at the end of the run? Hook onto locking cam notch? Yes Hook onto locking cam notch. Worn pivots in there somewhere? All looks okay. (not sharp enough lock)? The lock seems to be sharp.
Hmm. Can we see a picture? Yes.
The movement functions the same as the Kieninger in Steve Conovers "Chiming clocks" book.
Gordon Webb
gordon
Mar 7, 2007
233
Hello
I never noticed their are four pins that are in the reverce order 1234 and 4321 on pin barrel for the westmister chimes. I first set it up so the inside hammer picked up first and the others followed to the outside. I beleve it is correct now with the outside hammer picking up first and the rest following to the inside.
How did I ever get it correct before? The more I think I know the more I realize I have alot to learn
Thank you
Gordon
168,968
1,474,427
48,680
2,955
