Something is stuck in this Lookup. It keeps trying to open the link and then cuts you off saying you have tried too many times and has a 5 minute warning before trying again
And yet, I was just able to access the Waltham Serial lookup records.I also just tried to look up a watch tonight and could not. I agree
it is frustrating.
Rob
I said nothing about Hamilton records, which I also cannot access. My position as Administrator extends only to the Forums. I mentioned only Waltham. In reply to Jim's inquiry:Steven - I cannot access it either - I suspect the reason that you can is related to your status as an administrator. Is it related to the work on single login?
This is how I attempted
- open main site
- select company records from the research drop down list
- click on Hamilton Serial Number Search - this is where it starts to go wrong ...
- resulting page ...
Yes - Steven I changed the post while you were typing having discovered that [ctrl]+[rtn] saves the post - I was trying to insert a un-numbered line into a numbered list and I should have used [shift]+[rtn]I said nothing about Hamilton records, which I also cannot access. My position as Administrator extends only to the Forums. I mentioned only Waltham. In reply to Jim's inquiry:
Company Records - National Association of Watch & Clock Collectors, Inc. (nawcc.org)
This make no sense, why would you post this, it has nothing to do with the problem? and has caused John much wasted time..........And yet, I was just able to access the Waltham Serial lookup records.
Jim, I was simply pointing out the inconsistency in being able to access the Waltham records and being unable to access the Hamilton records. You should take it up directly with the HQ IT guys.This make no sense, why would you post this, it has nothing to do with the problem? and has caused John much wasted time..........
Apparently they have now broke something else, just tried and now either my user name and/or password is not valid, this is getting a bit ridiculousQuick update... The problem is being worked on by our consultants. You should now be able to log into the main website. Also, accessing back issues of the bulletin is working again. The Hamilton serial number lookup is still broken and I have let them know about that.
The only things the admins here on the MB can do is report problems to whoever it is who gets things done on the main NAWCC web site - which is completely independent of the MB. They have about as much power over the main NAWCC web site as the barista at your local StarBucks has over SB's corporate policy.there's absolutely nothing that the MB admins/mods can do to fix the problem. They have no control over the main web site.
Thanks for you replies Bill, at least you have, but someone must be in-charge of overseeing the tech operations of the main servers. Who has been currently working on them to get the Hamilton database stuff on-line? Someone is doing something and whatever that is, they are stuffing-up more stuff as they go along.The only things the admins here on the MB can do is report problems to whoever it is who gets things done on the main NAWCC web site - which is completely independent of the MB. They have about as much power over the main NAWCC web site as the barista at your local StarBucks has over SB's corporate policy.
I suspect that the fact that it's Christmas has something to do with it. And the winter storms. Much of the US has been pretty much paralyzed. AFAIK, Tom McIntyre probably has the most contact with the main web site. I know that they've been trying to implement a single logon for all the NAWCC sites, as well as upgrading the MB to a new version of XenForo & (I think) move it to the cloud. I had to resign my admin position a couple years ago, so I don't have any firsthand knowledge.
A pretty easy question Tom, I do not need the run around, who has been tinkering with the server, I see the same response as you have given me was not given to others asking about why the main servers were not operational for certain content.I think there is a related discussion on the agenda for the upcoming BOD meeting. Perhaps the discussion there will help members understand the situation better.
If you really want to discuss NAWCC Business and NAWCC personnel (which I would not recommend), then you should start a discussion in the members only discussion area.
This area is for getting help with Forum problems.
I think it is inappropriate to identify particular employees or consultants in a public discussion. It is difficult enough to hire qualified people to work in Columbia without the job exposing the employee to criticism here.A pretty easy question Tom, I do not need the run around, who has been tinkering with the server, I see the same response as you have given me was not given to others asking about why the main servers were not operational for certain content.
Thank you for your response Tom, and I agree with parts of it, but there has to be someone doing oversight and they must be up front and center to field the questions and be willing to take the positive as well as the negative responses, otherwise they are in the wrong game.I think it is inappropriate to identify particular employees or consultants in a public discussion. It is difficult enough to hire qualified people to work in Columbia without the job exposing the employee to criticism here.
If employees want to participate here, the Forum Admins and Moderators have no objection, but the BOD or the NAWCC management may want to restrict that activity.
