First is the Model 22. It has both wooden boxes and is in great shape, minus the outer leather strap which has ripped in the small section in between buckle hole 4 and 5. The movement is still very accurate too. I didn't check it down to the second but from March until mid Nov, it was still on the same minute as one of my quartz watches I used to originally set the time from. S/N is 2F28048 but I'm unsure of when it was made other than the 1941-43 posted in the database. I don't believe this one saw war action as there is no engraving on the case back and it came with a nice advertising/marketing card.
The model 23 I have has normal signs of age to the watch case and outer wood box, but the movement itself looks beautiful. The dial has a couple marks on it but the person I bought this from kindly sent me a second, mint condition dial that wasn't mentioned in the auction. A very nice surprise, for sure! The outer box has a hairline split from top to bottom in the top of it and some marks from wear over the years, but nothing is loose or effecting the integrity/function of the box. The inside, including the felt and cork shock absorbing pieces, are in great shape. The watch has normal wear to the case but nothing outstanding.
S/N is P13469 and case back info is as follows-
AN 5742-1
MFR's Part No.37297
Serial No. H- 7689
Hamilton Watch Co.
Now the questions I have for the Model 23. Firstly, are the hinges and outer latch made of brass? I'd like to bring back some of its shine. Should I assume that taking the screws out would strip the threads in the wood and give me a whole other set of problems? What would be the best products and way to go about this? Or should I just save the effort and see if the guys at Hamilton Parts have new ones? Haha. Lastly, below the latch, are 2 screw holes for a name plate. (The holes are 62mm apart from center to center) It's missing the plate and I'm having trouble locating one. Does anyone know where/if these can be found or what the proper term is for them so it's easier to search around?
And the third watch here is a 4992B with it's protective canister. Again, this one has your regular use knicks and scuffs but everything works as it should and the glass is very clean. The watch case makes it very apparent that this watch was well used but the movement is in great shape, hacking feature works perfectly and is still incredibly accurate. I wish I had more info than just a last name on the case to try and track down who the pilot was. S/N is 4C46671 and case back info is
AN 5740
MFR's PART NO.33106
SERIAL NO. H- 2318
HAMILTON WATCH CO.
My questions on this one are about the springs in the canister. As is obvious from the pictures the springs were stretched out and one out of place. Luckily, nothing is stripped, so it should all be fixable but the springs will still be stretched out kinda funky. Are these some specific springs for this canister or is this something a hardware store would have? Should I just work with what I have instead?
I have a couple last generic questions as well. I know about the few books on all Hamilton watches and on specifically their wristwatches but are there any on just their military watches? Or any book on american military watches? I haven't had much luck myself. Thanks for taking the time to read all this and help me out. The bulk of my collection are Walthams and I'm just starting to learn more about the Hamilton military watches.
AN 5742-1
MFR's Part No.37297
Serial No. H- 7689
Hamilton Watch Co.
AN 5740
MFR's PART NO.33106
SERIAL NO. H- 2318
HAMILTON WATCH CO.
